Cluster issue
Old Jun 17, 2014 | 06:14 PM
Rebirth98's Avatar
Rebirth98 is on a distinguished road
Cluster issue
Read a bunch and I didn't wash it. Doesn't see wet weather. Have a finned rr. My cluster lost power and I haven't checked all the fuses but they looked good to the eye. Question is cluster is dead but blinkers still work and high beam light still works bike still starts and runs normal. Rr issue or should I check the fuses with multi meter?
Old Jun 17, 2014 | 06:15 PM
Rebirth98's Avatar
And to add to this it's been raining non stop since the day it happened and with no garage I'm looking to find a nice easy this is your problem for when it stops raining
Old Jun 17, 2014 | 06:26 PM
Disconnect all connections blow out with compressed air, use dielectric silicone, reassemble, go ride.
Old Jun 17, 2014 | 06:59 PM
Rebirth98's Avatar
Yeah I read that again and screamed moron. She's tucked under an all weather cover and then a tarp. If it Ella it was working and very dry weather and mid ride just shut out after a down shift.
Will try removing all connections and reapplying
Old Jun 18, 2014 | 12:00 PM
Rebirth98's Avatar
Finally got a break in the weather blown fuse. It was an old original fuse and I also found a wire that could have been live and caused a short.
Old Jun 18, 2014 | 12:05 PM
Rebirth98's Avatar
Cluster issue-image.jpgAny chance someone can identify this RR for me?
Old Jun 18, 2014 | 12:07 PM
Rebirth98's Avatar
Serial number on back
Old Jun 18, 2014 | 05:31 PM
Bandit400man's Avatar
Bandit400man is on a distinguished road
Looks like cheap aftermarket (google TRANSPO)...pitch it an get a yamaha R1 reg/rec...plenty of info here on that, including cross reference numbers
Generation450X
May 25, 2009 07:14 AM
wardo996
Mar 26, 2007 09:39 PM
wardo996
Mar 21, 2007 10:20 AM
roisman
Feb 9, 2007 12:27 PM
Radiaoktiv
Sep 10, 2006 11:09 AM
