Cluster issue
Read a bunch and I didn't wash it. Doesn't see wet weather. Have a finned rr. My cluster lost power and I haven't checked all the fuses but they looked good to the eye. Question is cluster is dead but blinkers still work and high beam light still works bike still starts and runs normal. Rr issue or should I check the fuses with multi meter?
And to add to this it's been raining non stop since the day it happened and with no garage I'm looking to find a nice easy this is your problem for when it stops raining
Originally Posted by Rebirth98
(Post 374722)
(Post 374723)
Disconnect all connections blow out with compressed air, use dielectric silicone, reassemble, go ride. |
Yeah I read that again and screamed moron. She's tucked under an all weather cover and then a tarp. If it Ella it was working and very dry weather and mid ride just shut out after a down shift.
Will try removing all connections and reapplying |
Finally got a break in the weather blown fuse. It was an old original fuse and I also found a wire that could have been live and caused a short.
1 Attachment(s)
Attachment 17279Any chance someone can identify this RR for me?
1 Attachment(s)
Serial number on back
Looks like cheap aftermarket (google TRANSPO)...pitch it an get a yamaha R1 reg/rec...plenty of info here on that, including cross reference numbers
