Cluster Gauge Backlighting... All bad
Old Apr 17, 2008 | 11:26 PM
Shortlived99's Avatar
Shortlived99 is on a distinguished road
My tach gauge back lighting went out on the right side, I afraid my low fuel light isnt working too.
Anyone know if a wire may have just got disconnected or if those lights can go out? Im a little confused.
I did a search and found nothing on this. I checked all the wires on the back of the cluster and nothing seems to have come unplugged. I was workin on the bike earlier (hammering my fairing stay back into place). Wondering what I did.
Old Apr 18, 2008 | 04:35 AM
drew_c14's Avatar
Do you have a multimeter? If so you can check the wiring diagram in the manual and find out what wire is what. Then check for power and ground and the right places.
Old Apr 18, 2008 | 06:36 AM
superbling's Avatar
You could have cracked the cluster and broken the contacts with one of the hits. Hopefully you just cracked the bulbs although the the RLOD is an LED I believe. Swap the tach bulb with a known good bulb to see which is bad: bulb or wiring.
Old Apr 18, 2008 | 10:28 AM
synaptik's Avatar
synaptik is on a distinguished road
the bulbs can go bad (not sure on the RLOD) but i know the tach light and the one behind the temp gauge can, i had to replace both those when i got my bike
Old Apr 19, 2008 | 06:21 PM
Can't you jump the connection unter seat (from the tank) and test the reserve light that way?
Old Apr 20, 2008 | 07:45 PM
Well, my reserve light is working. Ill test the bulbs... How difficult is taking apart a cluster? Never done it, not even on a car.
Old Apr 20, 2008 | 07:51 PM
superbling's Avatar
You don't take it apart per se, simply remove it from the fairing stay, pull the bulbs out from the backside, and remove from the wiring harness connector. Less than a buck for replacements at the auto parts stores.
Old Apr 20, 2008 | 09:41 PM
Awesome thanks, im sure i would have figured it out, but it would have taken me a minute.
So that means u can use any colo leds u want back there??
I love the red/white gauges, but its nice to know.
vtrj
May 20, 2007 03:49 AM
MarineHawk
May 11, 2007 09:31 PM
wardo996
Mar 26, 2007 09:39 PM
wardo996
Mar 21, 2007 10:20 AM
Verne
Aug 15, 2006 07:31 AM
