cct failure
Old Mar 30, 2014 | 04:46 PM
foosfan's Avatar
foosfan is on a distinguished road
cct failure
ok so i think ive had cct failure......where do i go from here
Old Mar 30, 2014 | 05:09 PM
sjscicluna's Avatar
ouch sorry to hear..
not sure hopefully some one with the knowledge can help but i guess it depends on the damage done
Old Mar 30, 2014 | 05:14 PM
jscobey's Avatar
Realł sorry to hear that. Can you post some more info. What makes you think you've had a failure? Describe what happened. The more info you post the more people can help.
Makes me glad I just installed manual CCTs last week. I hope the damage isn't to bad
Old Mar 30, 2014 | 07:01 PM
rick's Avatar
rick is on a distinguished road
need more info.
You my only need to change the CCT's. On the other extreme you could need piston, cyl work and a new head.
Any idea which cyl failed?
A preliminary check is to turn the engine with a wrench at the crank(right term??) bolt behind the big hex hex cap on the stator cover. Don't brute force you way through if it doesn't want to turn over. If it turns over normally without binding there is a good chance valves and piston didn't kiss.
I'd remove the valve covers and check cam timing. If timing is correct, chance of any damage is very low. IF timing is off I'd check valve clearances and then a leak down check and go from there.
If you need to get the head off, it's not very hard to do on this bike. Used cyl head are not very expensive either.
Old Mar 31, 2014 | 02:24 PM
mcg's Avatar
mcg
mcg is on a distinguished road
Just a note take your spark plugs out and hand crank as described above.
Hope you only jumped a few teeth.
I just installed manual cam chain tensioners a few weeks ago...phew!
Good Luck!!
Old Mar 31, 2014 | 03:27 PM
Where are you located?
Old Mar 31, 2014 | 08:20 PM
dmount76's Avatar
dmount76 is on a distinguished road
My front cylinder CCT went out recently. Engine made a sound like a chain slapping then a big clunk. I ended up bending 2 valves in the front head. I just replaced the valves and a new head gasket, made manual CCT's and put her back together. Runs like a top now. Good luck.
Old Apr 4, 2014 | 04:41 PM
foosfan's Avatar
thats what mine did but no clunk....was it hard to do? expensive?
Old Apr 4, 2014 | 04:42 PM
foosfan's Avatar
medford oregon
Old Apr 4, 2014 | 04:45 PM
foosfan's Avatar
i did as described ..... no binding but whats sounds like a slap in th front cyl
Old Apr 17, 2014 | 06:34 PM
Tofazfou's Avatar
Tofazfou is on a distinguished road
I seriously HATE (right now at least) that i changed mine. I have a 2003 and NOTHING and i repeat...NOTHING happened to make me change mine but reading forums. My bike ran great before the swap and actually runs fine now but it has a strange NOISE coming from one of the cylinders upon startup. I've backed off and back off and then went in and went in some more based on all the reading i've done here and i'm still not "SURE" about the mod. Upon a cold start, one of my cylinders makes a weird "WHOOOOOMP" sound whereas it never did before the swap. And this is during the actual START of the bike and NOT the running of it. No matter how loose or how tight i make the CCT, it makes that noise. My CCT's are on the LOOSER side as opposed to the TIGHTER side for sure.
My OEM 2003 CCT's where strong as F#@K when i removed them and seemed to have a TON of life (spring tension) in them still to put tension in that chain. After i removed the OEM's, i wonders why i even touched them based on how strong the spring was in the OEM CCT.
I took my bike in to have the front fork internals changed out and i talked to the service manager and he responded that he has never in his 15 years of Honda service seen a CCT fail on a VTR!
But of course, that doesn't mean that they don't fail.
Old Apr 17, 2014 | 09:34 PM
jscobey's Avatar
the noise is just while the bike warms up. if you followed the procedure, you should have 5-7mm of slack on the cam chains. id stop messing with them because if you go too loose, CLACK! and if you go to tight youll wear out the cam chain pre maturley. id open things up and re-adjust to 7mm of cam chain slack .
Old Apr 17, 2014 | 11:46 PM
I have to know, what are you expecting a spring to do before it fails?
Some CCT's fail with a couple thousand miles on them and some that have 70 thousand miles or more on them. Changing stock CCT's to manual CCT's are (for me) a peace of mind & insurance. When a CCT spring breaks, there is usually very little to no warning.
Like scuba steve said, stop messing with your manual CCT's while it's running, because you could do damage to your engine by unscrewing it to far. Just take the valve covers off and set the tension properly.
I can't think of anything that would make the noise you describe on a correctly running VTR engine. Just thinking out loud here, but maybe you have so much slack in the cam chain, that when you start it, the slack is taken up very quickly and you here that noise? But if there was that much slack, the cam sprocket(s) would surely skip some teeth on the cam chain.
Last edited by CruxGNZ; Apr 18, 2014 at 12:01 AM. Reason: I ate a Culvers burger and cheese curds with a cherry malt
Kendrick
Jul 18, 2011 12:27 AM
Riff
May 27, 2009 09:18 AM
LineArrayNut
Oct 28, 2008 04:39 PM
Scoutpilot
Oct 3, 2008 09:36 PM
BiggDaddyKool
May 31, 2007 01:36 AM
