carbs rebuilt stage 1 now back fireing
Old Apr 13, 2010 | 08:11 PM
amazin's Avatar
amazin is on a distinguished road
I tried to search but nothing found that was clear
ok I bought this vtr. The day I got it the floats were sticking and filling the airbox with fuel. i took it to a honda mechanic (friend off of a local forum). We opened it up and 293.44 later plus a dyno jet stage one kit, petcock rebuil kit. Now it runs strong but back fires alot.
there is a Kand N on the bike soon to be BMC. Staintune high mount cans.
Anyway new fuel in tank. and the only thing wrong now is back fires.
I would really like some help from you guys.
Do I need to change te jets? Burn the Bike? Or re we missing something?
Thanks guys for your help
oh yeah its a 98 hawk
Old Apr 13, 2010 | 08:19 PM
Little_Horse's Avatar
2nd mouse gets the cheese
Do you know what the setting where for the carbs? Main jet size, pilot jets, needle position, and mixture screw setting? This will help us help you. Also backfires that sound like 50 cals are bad settings, or poor spark, backfires that sound like small puffs usually during decel are most of the time related to the pair system which most of us have removed. So 50 cal backfire?
Old Apr 13, 2010 | 09:40 PM
Syclone's Avatar
Boosted
backfires when decelerating? If so, it's probably just the PAIR system doing its job.
Old Apr 14, 2010 | 02:31 AM
residentg's Avatar
+1 ^. There is a great write up here:
https://www.superhawkforum.com/forum...ad.php?t=20918
You can get the block off plates here:
https://www.superhawkforum.com/forum...ad.php?t=18515
While you are in there, adjust the TPS:
https://www.superhawkforum.com/forum...ead.php?t=9876
These easy mods made a significant improvement to my bike. Starts right up - one push of the button, no more decel popping.
Oh yea, put in some APEs too, and check the valve clearances, and sync the carbs...
JB
Old Apr 14, 2010 | 02:32 PM
revhead1957's Avatar
revhead1957 is on a distinguished road
Leaking exhaust will also cause exhaust popping - look for telltale black soot at all joints.
Excessively lean jetting will also cause backfiring on throttle over-run.
Old Apr 14, 2010 | 04:26 PM
steve29's Avatar
steve29 is on a distinguished road
I just went thru the same thing. Dj stage one installed, then would run strong everywhere except small throttle openings. Usually between 3,4k rpm. It would sort of sputter, then backfire thru the carbs. Today I dialed the tps in at 502 ohms. No more backfires! I never thought it would make such s difference, but it did. Maybe try that if you don't already have that done. And while you're in there, rip out that pair system. Great writeup on both in the knowledge base section.
Old Apr 14, 2010 | 05:28 PM
amazin's Avatar
sweet guys. I will try your suggestions. Thanks again I will let u know what it does
Old Apr 14, 2010 | 06:17 PM
steve29's Avatar
No prob. I don't claim to know near what some of these other guys do, but that sounds so similar to what I dealt with that I had to give my 2 cents. Hope it works for you.
divingindaytona
Jul 22, 2011 03:37 PM
Circuit_Burner
Apr 27, 2009 09:40 PM
pigwings
Apr 19, 2008 12:48 AM
J-Bird487
Sep 21, 2007 10:39 AM
zakthor
Aug 18, 2005 10:22 AM
