Carb Slide Question
Old May 20, 2013 | 07:46 PM
zanoj883's Avatar
zanoj883 is on a distinguished road
Carb Slide Question
Hey everyone,
After a carb cleaning i started hearing my carb slides chatter at idle when the engine is at operating temp. If i give it a little gas it goes away for a minute then starts again.
Is this something i should be worried about? Does it indicate something in there is failing i.e. the diaphragms?
im going to tear into the carbs this weekend to tune them and just need to know if i should order some new slides. Thanks All
Old May 20, 2013 | 08:07 PM
It's pretty common, so nothing to worry about.
Old May 20, 2013 | 08:14 PM
zanoj883's Avatar
thanks hawk
Old May 27, 2013 | 06:54 PM
kelowna1971's Avatar
kelowna1971 is on a distinguished road
Is this a loud tapping that comes and goes at idle, that i tbought was loose cam chain from worn cct's.
Can carbs rattle/tap pretty loud?
Sounds like a lifter tap noise from old v8.
Old May 27, 2013 | 08:05 PM
GlockPointer's Avatar
Connie Demico does toad?
I get the carb chatters now too but it's not louder than any of the other usual noises. If it doesn't hurt anything then I'm not going to worry.
Old May 27, 2013 | 09:18 PM
Yes normally it is.
Old May 27, 2013 | 09:30 PM
zanoj883's Avatar
The slide noise sounds more like plastic on metal ( i guess cuz it is )
After following 8541HAWK's carb set up i dont get the noise anymore and it feels like a new bike. Im a little rich on the bottom end so im gona mess with them again this weekend.
Carb set up
Old May 27, 2013 | 09:38 PM
After following 8541HAWK's carb set up i dont get the noise anymore and it feels like a new bike. Im a little lean on the bottom end so im gona mess with them again this weekend.
Carb set up
One reason is by plugging a lift hole, you have slowed the slide down so it is not slamming shut as hard.....at least on the front
Old May 27, 2013 | 09:45 PM
SIRR1's Avatar
Deals Gap is a Hoot!
SIRR1 is on a distinguished road
Carb slides
Did you pull the carburetor slides off the throttle cables on this lastcleaning / rebuild?
If so you may have accidentally mixed up the slides placing slide #1 into carburetor#2 and slide #2 into carburetor #1.
Carburetors due wear down over time from the violent amounts of air gettingpulled through them and the two carbs will wear differently and develop theirown patterns of wear to the point that one of the slides is loose in theunmatched set.
If you can live with the rattle the only hazard I can see from a situationlike this would be one of the slides sticking open when you back off thethrottle.
JMO / SIRR1
Old May 27, 2013 | 09:55 PM
zanoj883's Avatar
Ya, your set up worked great. I forgot to remove the stock shim from the front needle so i think thats why im a little rich.
JMO / SIRR1
I only do one carb at a time so not to mix things up
Old May 27, 2013 | 10:05 PM
JMO / SIRR1
Umm CV carbs.....vacuum slides..... they bounce around at low RPM it's just how it is.
Throttle cables just go to the butterflies.
It causes no issues and happens even on new carbs and\or slides.
It is just a SH noise....
Old May 31, 2013 | 07:47 PM
zxbud's Avatar
Slide Clatter
Yes, this is what I noticed too. No more slide clatter when engine is cold and kanoodling up the hill in 1st gear. Engine responce is maybe a little soft at say 6krpm in 2d when snapping the throttle open but, who cares? I don't do much of that anyway.
chemomche
Dec 3, 2012 08:32 AM
jdavidc85
Aug 29, 2012 11:02 AM
GTS
May 1, 2012 04:38 PM
skoshere
Sep 30, 2009 02:09 PM
Edwards07
Aug 24, 2007 08:28 PM
