carb problems
Old Jan 10, 2011 | 05:20 PM
waterbug89's Avatar
waterbug89 is on a distinguished road
carb problems
just got a hawk always wanted one here is the scoop bought this 98 hawk for $1,000 dollars the bike has sat around for 9 years or so it has 4,200 miles on it. it was taken to the dealer about a year and a half ago to get it running again they got it running rebuilt carbs and such guy lost interest again bike sat for the rest of the time again. i broght it home got a new battery it turns over but leaks gas out of the front carb vent line iam assuming all the vent and emisions stuff has been removed do to the open vent line any help would be great thanks
Old Jan 10, 2011 | 07:13 PM
waterbug89's Avatar
went ahead and just pulled the carbs cleaned them up the front one had some crap in it but i was wondering should my main jets be different sizes on each carb?
Old Jan 10, 2011 | 07:23 PM
Little_Horse's Avatar
2nd mouse gets the cheese
thats normal larger jet in the back carb for extra cooling for the rear cylinder
Old Jan 10, 2011 | 07:27 PM
The carbs on our bikes do need a little attention from time to time.
Welcome to the "unofficial" Superhawk Forum.
Old Jan 10, 2011 | 07:28 PM
BeerHunter's Avatar
Slacker
I just went through the same thing with my Hawk, only the rear was leaking. Stuck float was remedied with cleaning, along with cleaning out all the jets which were mostly clogged after sitting for only 6 months. Zero dollar repair.
The rear main will be a little larger than the front.
Old Jan 10, 2011 | 08:48 PM
waterbug89's Avatar
alright got the carbs back on no more leak bike still wont start believe i have fuel now dont know about spark will check it tomorrow how long should i leave the chocke on turning it over till it pops or till it starts, thanks for the help guys
Old Jan 10, 2011 | 09:03 PM
Check for PIVLR = possible inadvertent vacuum line relocation.
Make sure the vacuum line to the petcock is on the left side vacuum port. The bottom port is the diaphragm vent and should be left open. It's a common mistake after removing the tank for the 1st time...I know.
Oops, I just remembered it's PVLIR = petcock vacuum line inadvertent relocation.
I never have been good with acronyms with more than 3 letters.
Old Jan 11, 2011 | 08:09 AM
nothing's Avatar
ride it out
you may have to sync those bad boy carbs, does anybody have the link for syncing using the snapple bottle method and that extra fitting you need to buy for the carb?
Old Jan 11, 2011 | 10:45 AM
RCVTR's Avatar
It's probably not a sync problem.
If it was flooded, you probably have fouled plug(s). Take the plugs out and spray with contact cleaner and let them dry. Then check for spark.
Keep the choke (enrichment jets) on until the engine starts.
Old Jan 11, 2011 | 11:24 AM
nothing's Avatar
ride it out
ya it is surely not required but while he has them out it should get done, and I was hoping somebody could remember that link or post because my carbs are out too
Old Jan 11, 2011 | 04:07 PM
waterbug89's Avatar
thank you every one came home with new plugs bike fired up, bad plug what is evey one running for plugs going to start new thread on lowering my bike, little on the short side thanks again
Bdalefire115
Sep 18, 2012 12:41 PM
streetfighterhawk2000
Oct 20, 2011 09:47 AM
geekonamotorcycle
Jun 24, 2011 03:08 PM
Jetfever
Oct 21, 2009 07:54 PM
ride57
Jul 19, 2008 06:04 PM
