carb issue
Old Aug 2, 2011 | 06:56 PM
3amta3's Avatar
Jack of all Master of non
3amta3 is on a distinguished road
carb issue
ok all other stuff figured out now i have a problem with my carbs. now with the carbs at low take off acceleration the carbs have a gargul and a slight rattle once above 2500 rpm all seams normal.
do you have the filters in the air cleaner for the carb valves? it sounds like to me that the diaphragm slider is making that noise but not sure how to fix it... any help?
Old Aug 2, 2011 | 07:11 PM
Well it is an "Internet Noise" so it makes it real hard but what it sounds like to me is you are hearing the carbs slides open and close. That is why it goes away at above 2500 RPM.
So I would say it is just a normal "SH noise" and not to worry about it.
Old Aug 2, 2011 | 08:16 PM
Can't tell if it's a question, but you should have those little trapezoid foam filters in the airbox for the carb slides. Otherwise they're exposed to whatever gets sucked in there...
Old Aug 3, 2011 | 05:23 AM
3amta3's Avatar
i noticed today that the carb noise goes away the warmer the bike is too.... i have herd you can seal one of the holes on the slider to help fix the issue, what do you guys think? other than this problem she is running like a top. i guess it is just me being critical.
has anyone herd of converting a SH to fuel injected?
AK Ronin
May 19, 2011 08:20 PM
FastRED
May 11, 2011 01:45 PM
poppazuti
Oct 6, 2010 07:26 AM
dshakes
Jun 16, 2010 03:21 AM
skoshere
May 28, 2010 09:33 PM
