carb idling question
Old Aug 11, 2007 | 08:31 AM
bradcarrier's Avatar
bradcarrier is on a distinguished road
my bike is running great, 1998 30K, just replaced timing chain tensioners, my question is about the carbs, she is up and down idling between, 1000 to 1500 rpms, up and down up and down, occasionally acts light she wants to die when idling, any suggestions, quick fixes or does the carbs need rebuilding? Thanks in advance.
Brad
Old Aug 11, 2007 | 10:28 AM
just played with the carb sync screw, adjusted it out one turn, then adjusted the idle, same result, up and down idle, any thoughts. Thanks
Brad
Old Aug 11, 2007 | 03:13 PM
redman's Avatar
Sounds like maybe there's a small air leak around the carb boots or one of the rubber vacuum hoses is old and cracked where it has to stretch around a fitting. This would allow a bit of air to lean the idle, revving that side. Check all areas for old rubber. Idle warmed up and spray starter fluid around carb bases and tubes...if it revs up...that's where your leak is.
Old Aug 22, 2007 | 07:05 AM
If you rejetted with a Factory kit they include #50 pilot jets. Installing these will cause the bike to run very rich at idle and cause the symptom you describe. Stick with the stock #45 jet if this is the problem.
Old Aug 22, 2007 | 05:57 PM
redman's Avatar
Hmmm...thanks Greg. Mine's idle is a bit erratic too. I just had the carbs off (wish I'd known about the D shaped pilot screw THEN!!!) to do the TPS adjust and valves etc. I synch'd and she runs great but idles not right yet. I set it down at about 900 and that helps. Guess I'll pull the carbs, remove and slot the pilots and check what jets are in there. PO said there was a Factory Kit in there.
Old Aug 22, 2007 | 11:41 PM
Well, if there's a factory kit then that may be the culprit. Sometimes folks just install everything in the kit whether it's needed or not. That's not really the intention of the kit, especially since they give you a decent assortment of main jets.
bpw
Nov 26, 2013 10:16 AM
nath981
May 3, 2010 09:30 AM
reaper
Oct 9, 2007 04:12 PM
bluethunder
Jun 1, 2007 06:29 AM
99Hawkboy
Aug 14, 2006 07:03 PM
