Carb help!! PLEASE!
Old Aug 4, 2007 | 06:41 PM
saxman's Avatar
saxman is on a distinguished road
Carb help!! PLEASE!
I have been having problems with the SH not responding. Thinking it was something I did by hooking up the vacuum line wrong to the petcock, I replaced the petcock. Still does not have near the power and misses when hard on the throttle. Tonight I tore the airbox off, and inside the intake for each carb are the black "sliders" above the butterfly's, that I assume run off the vacuum also. The one on the rear carb jumps back and forth slightly when you turn it over and hold the throttle open, but the one on the front does not. Shouldn't it also? The front is where my missing/ popping is going on. Is this adjusting the amount of air coming in along with the butterfly valves? Or is this adjusting the intake of the jets? I don't know much about it. What could be causing this? It moves freely by hand, and actually springs back to home position a little quicker than the rear one...I am at a loss. I have not messed with them, so don't know where to go from here....someone PLEASE help! Maybe I am way off here...
Old Aug 4, 2007 | 07:58 PM
superbling's Avatar
Good detective work. Yup, the slides can stick (BTDT) and cause **** poor running that can be difficult to pin down.
You can remove them without removing the carbs but the front one is a real bear space-wise so I strongly suggest pulling the carbs out of the boots (not full removal) to get some more working room. Clean and lube both the slides and the channel in the carbs. I used silicone spray but there maybe something better out there.
I now wonder if this is the first sign of weakening diaphragm springs.
Old Aug 4, 2007 | 08:07 PM
saxman's Avatar
Thanks superbling......but.......it moves very freely. I don't think that it is sticking. Would the spring weakening cause it to not open or not close back up? It closes fine, but won't open on it's own when turning over. Could it be the diaphragm is shot? Do I need to remove the gray plastic cover ( 3 phillips screws) on the front of the intake to find it inside? It started doing this after she sat for a few months getting repainted, if that gives any clues.
Old Aug 4, 2007 | 08:27 PM
superbling's Avatar
Oh I see. Sounds like it's damaged (hole) and vacuum can't pull it open; still gives the same symptoms as a stuck one tho'.
Yup, it's under the black cap with three screws. They should be VERY tight (locktite???) thus why it's good to have some working room. I'd try cleaning/lubing first as they aren't cheap.
Old Aug 4, 2007 | 08:31 PM
saxman's Avatar
OK..well....I pulled it out, and have a 1/2" tear in the diaphragm..UGG. But, at least I now know. Maybe try to "fix it" with shoo goo for the time being until I get one ordered..duct tape, bailer's twine and shoo goo hold my household together!!! I can't be without my baby!
Thanks for the help!!!!!!!!!!!
Old Aug 4, 2007 | 11:32 PM
Let us know how it turns out. I don't think Shoo-Goo will last long so you'd better just order one now. Can't really think of a permanent fix for these that will not affect its operation. A tire tube patch kit might work but they are pretty thick. Maybe just the rubber glue and a piece of material similar to the diaphragm, or a small piece of heavy duty plastic trash bag.....
Man, this is so ghetto....just order a new one!
Old Aug 5, 2007 | 05:54 PM
saxman's Avatar
LMAO Hawkrider.....well, the shoo goo DID work.....well! I ran it this morning to work, all day on breaks, and then home...and I didn't baby it (+8000rpm), just to see how it would do. So far, so good. I already ordered one last night that should be here Friday, so fear not!! I SHALL have the real deal soon. I just needed a quick fix so I could ride it today. I can't be without my baby, not even for a day!
Thanks everyone!
Old Aug 6, 2007 | 08:07 AM
camaroguy72's Avatar
camaroguy72 is on a distinguished road
mine were stuck too but not because of damage, just they were like stuck as the bike was sitting with gas in it for 2 years lol.
Old Oct 1, 2007 | 08:39 PM
saxman's Avatar
OK hawkrider....my shoe goo finally wore out today, so I am replacing the diaphragm. My question now is, how do I get the needle out of the old sleeve?
Old Oct 1, 2007 | 08:51 PM
filter69's Avatar
Thats Mr Dill hole to you
Just did this tonight you take a screw from the cap you removed on the carb diaphram and screw it into the round stick pressed into the carb slide and "Gently" pull up while wiggling and it will slide right out carefull to keep washer on end of needle from getting lost then lube up o-ring and put it all back in the new one i also use a silicone spray on the sliders works wonders.
Old Oct 1, 2007 | 09:25 PM
RK1's Avatar
RK1
Smart thing to do is download the service manual. I don't have a link, but if you search for "98-03_VTR100F" you'll find it somewhere.
Old Oct 1, 2007 | 09:29 PM
RK1's Avatar
RK1
I left out a zero. Should be "98-03_VTR1000F"
Old Oct 2, 2007 | 12:13 AM
saxman's Avatar
Great, thanks for the help guys. She's all back together and went for a midnight ride (OK, 2:00am).....daddy likes!!
Old Oct 2, 2007 | 06:24 AM
reaper's Avatar
Saxman:
The service manual download link is in the Knowledge Base section. This is a good thing to have if you don't already own one.
Old Oct 2, 2007 | 10:53 AM
saxman's Avatar
Cool...thanks Reaper. Will have to get it.
awg13
Aug 28, 2010 06:16 PM
mcadena89
Jun 3, 2009 12:04 AM
mattvdsande
Mar 16, 2009 11:12 AM
FordsnRebels
May 3, 2007 07:10 AM
Speed_Demon
Apr 3, 2007 05:25 PM
