Can't open my tank!
Old Jun 10, 2009 | 11:28 AM
JoeSnowden's Avatar
JoeSnowden is on a distinguished road
Can't open my tank!
Hey guys, I bought a firestorm a few months back which needed some work (well pretty much just putting it back together) and have pretty much finished. I thought I better drain the tank and fill up with fresh petrol, damn it, the tank won't open. Now I'm not sure wether it is a different tank hence the key not fitting (I have two keys with the bike a long one and a shorter one, niether fit). How would you got about opening it?
Joe
Old Jun 10, 2009 | 11:33 AM
worst case remove the whole cap unit with a allen wrench.
But you really want a key that works eventually. By not fitting, what do you mean? Doesn't turn or literally won't fit at all? Might it just need some WD40 or the like to free it up?
Old Jun 10, 2009 | 11:43 AM
JoeSnowden's Avatar
I tried taking the whole cap off but you need to undo it to get it off (bugger). The shorter key fits in there perfect, it just won't turn it, I'm going to squirt some WD40 down there and hope for the best.
Cheers, Joe
Old Jun 10, 2009 | 12:03 PM
Also try turning the key around.. I know they are supposed to be symmetrical, but I have two keys for my bike and one of mine will only open the gas tank when put in a certain way around.
Old Jun 10, 2009 | 05:26 PM
You will need a locksmith if you can't get the key to work.
Old Jun 10, 2009 | 06:11 PM
k-d-williams's Avatar
Mine will not open the cap until you press down hard on top of the cap with one hand while turning the key with the other.
Old Jun 10, 2009 | 06:16 PM
Hotbrakes's Avatar
I second that. If that doesn't work...like Greg said...locksmith. Or a drill and get a non locking Vortex cap, but then there's all the shavings...
Old Jun 10, 2009 | 07:21 PM
Once a locksmith opens it, you can remove the assembly by unscrewing the 3socket head cap screws and take apart the cap (under the gasket is a snap ring type deal and washer and the lock mech slides out) and gut the tumblers so anything that fits in the lock will open the cap.
Old Jun 10, 2009 | 10:25 PM
Circuit_Burner's Avatar
guru of things sparky
If the key looks new and no wear on it ... take it and rub the edges down a tad ( smooth it up a little ) on a wire wheel or similar buffing device.
New or recently made keys have edges on them a lot of the time that hang up on the tumbler.
Old Jun 11, 2009 | 08:34 AM
JoeSnowden's Avatar
I'm starting to think that it's not the original tank tbh. The smaller key opens the seat latch fine and the longer key operates the ignition fine but niether will open the tank. I managed to open it with the hook bit on a pair of nail clippers though!
The thing is it opened real easy and within a few seconds with it too! Put petrol in, shut it, I'll be buggered if I can open it again! Damn it, haha
Joe
Old Jun 11, 2009 | 02:14 PM
tbartley's Avatar
Well...there's your new key!
Old Jun 11, 2009 | 11:39 PM
shayne's Avatar
Something is bodgy if you have a short and a long key. One key should do all three functions.
Old Jun 12, 2009 | 01:39 AM
JoeSnowden's Avatar
hmmm, that is odd, I thought it was normal as I have two for my Hawk GT (well Bros). I hope I can get the bugger open, I'll nick the one off the Bros whilst it waits for its new (840cc) engine...
Thanks guys.
Joe
LineArrayNut
Dec 12, 2008 09:44 AM
adam75dfw
May 25, 2008 10:22 PM
vtrj
Mar 11, 2007 04:10 AM
caffeineracer
Sep 23, 2005 03:49 PM
nomead
Jun 25, 2004 12:56 PM
