BMC vs. K&N
Old Mar 23, 2010 | 06:55 PM
98ILVTR's Avatar
BMC vs. K&N
Which do you guys prefer?
I have a K&N, and I was just curious about the BMC....
Old Mar 23, 2010 | 07:42 PM
mboe794's Avatar
I like my BMC street filter. Quality between the two seem similar but the BMC has the block off plates molded into the underside of the filter just like the stock one.
Old Mar 23, 2010 | 07:53 PM
OEM
Old Mar 23, 2010 | 08:02 PM
Forum member Tweety did some testing on his personal dyno and found that the K&N did offer the possibility of higher peak numbers but also produced dips at lower speeds. The stock filter works well across the board and comes highly recommended. Finally, he found that the BMC made it possible to boost power slightly across the board once properly jetted for. Do a search and you'll surely find his write-ups (if he doesn't jump into this thread anyhow)
Old Mar 23, 2010 | 08:04 PM
Little_Horse's Avatar
2nd mouse gets the cheese
I am running a BMC filter, no flat spots in my jetting, getting 40 to 45mpg on the highway. Took me a little bit to get the jetting right I tuned it for smooth performance and MPG's I could care less about 1 to 2 ponies on top. Stock mains needle 5 and 1/2 notches screws turned 2.75 revolutions. I would recommend the filter as it is also cleanable just like the kandn.
Old Mar 24, 2010 | 06:50 AM
RickB's Avatar
I am happy with my K&N, I did shim the needles with a #4 brass washer and have no flat spots.
Old Mar 24, 2010 | 07:19 AM
andy9743's Avatar
i have a BMC race and once jetted for properly it runs excellent...never tried oem or k&n to compare to tho.
Old Mar 24, 2010 | 07:24 AM
Something to note to for people, I have jetted three supers, and all of them even though they had similar mods had vastly different jetting and responded differently to tweeking. I have no idea why, it would seem they would all be close, like one setting working for everyone, but it doesn't work that way. I am just saying that to suggest why some people have success with aftermarket filters and others don't, at best its a hit and miss deal with one.
Old Mar 24, 2010 | 01:17 PM
That's quite true... I have worked on my own and three others, and had all of them on a bench tuning them... All of those three had basicly just slip-on's added, and was stock apart from that... None of them was the same, none of them ended up with particularly similar jetting, but with very similar results...
I tried the K&N in all of them, and every time it made the most top-end, no compromise... But every time it also made the biggest holes... The choice was "Big power - big hole" or "Medium power - medium hole" with that filter, fuel efficiency isn't even close to that equation...
The OEM filter actually makes more power with decent fuel economy than the K&N does when you get rid of the biggest holes, and at that point the K&N still keeps the fuel consumption sky high in compared to the OEM...
The BMC Race filter is apparently the same as the K&N, but I haven't tried it... Both are useful only on a completely built Stage 1/Stage 2 engine with full exhaust and the works, in my opinion... but again, YMMV...
The BMC Street is my personal favorite... In the middle somewhere... Flows more than OEM, but less than the two race filters... Makes decent power with a stock engine with some slip-ons and jetting, without sacrificing fuel efficiency... (And even more than decent with a modified engine like mine...)
Both the Race and Street BMC filters are cleanable like the K&N... Unless you have done serious work on your engine, do yourself a favor and use an OEM filter or a BMC Street...
(Was that what you where waiting for mikstr?... )
Old Mar 24, 2010 | 01:32 PM
RK1's Avatar
RK1
andy;
What exhaust are you running? Which mains and pilot jets?
Old Mar 24, 2010 | 01:35 PM
I knew you wouldn`t disappoint
Old Mar 24, 2010 | 01:38 PM
how can you tell the difference between the race bmc and the street bmc filters?
Old Mar 24, 2010 | 02:00 PM
They are marked first of all... And then the color/texture of the filter is different...
Old Mar 25, 2010 | 07:41 AM
andy9743's Avatar
Originally Posted by RK1
andy;
i'll have to look at my records when i get home on the jetting...my exhaust is remus that i've shortened by about 9 inches.
Old Mar 26, 2010 | 07:59 PM
Fish's Avatar
FRAM....good flow, good power.....and $8 to replace
Old Mar 27, 2010 | 06:39 AM
What part number are you using to get a FRAM Air Filter that fits the SH? And what store or source are you using to get it?
Old Mar 27, 2010 | 07:39 AM
98ILVTR's Avatar
Interesting.
I've noticed my Hawk screams at the top end. Down low it feels great. But, right at 4000rpms, there is a slight hole. It runs lean there. I have a jet kit, which is installed, and I had to increase the Slow Jet to a #50, and the Needles are in Position 3 from the top, Position 4 from the top is too much gas. The Main Jets are at 178F, 180R.
So, thats what I was curious about.
I can deal with a slight hole in the mid for now, because I ride hard and most of my riding is at higher rpms. But I will probably eventually get a BMC...
Old Mar 27, 2010 | 08:59 AM
Originally Posted by 98ILVTR
Interesting.
And that is the infamous K&N hole right there for you... And believe me, you don't know what you are missing since you never had it... Try sticking a OEM filter in there and work on the jetting to get it right, and the midrange of the VTR goes from "fun for a 100hp bike" to "beats the snot out of a 130hp bike" and the top end should stay fairly similar, just goes flat a bit lower in the revs, but the midrange more than makes up for that...
Then add a pair of those velocity stacks that may or may not work and it gets really fun...
Old Mar 27, 2010 | 09:08 AM
I think what people running the fram filter are doing is they take an oem filter cut the element out then replace it with a similiarly sized fram air filter. I can't tell you if it works real well. Crackerjackman was running it like this but the filter was just laying in there not sealed very well and I have a feeling some of his jetting problems where caused by that, because once everything was buttoned up in the air box his bike ran alot better.
Old Mar 27, 2010 | 09:32 AM
98ILVTR's Avatar
I had to throw away my stock filter, because the thing was trashed by mice that somehow got into it over the winter. I will have to see what I choose.
Old Mar 28, 2010 | 07:38 PM
Fish's Avatar
yup.....just remove the old OEM elements....RTV in a FRAM 3717 (research all done for ya) and I made a cut-out in a piece of tin/sheet metal to sandwich filter to OEM houseing.
This process was posted here years ago under my old user ID.
Fish
Old Mar 28, 2010 | 09:16 PM
After my last set of mods I had a stumble at 3-4k. Made the bike real hard to ride. I took it back to the mechanic and he apologized for missing the set up. He came over a couple weeks later and installed half-step washers to the needles.
Rocket time! He's twenty years my junior and descibes the bike as "crazy fast" - it is and I mostly never use it.
Yeah, well mostly!
Old Mar 29, 2010 | 07:54 PM
98ILVTR's Avatar
Yeah, well mostly!
He used another wash underneath the e-clip on the Factory Pro needles? Or he did this on the stock needles? Shimming stock needles is not uncommon; but the Factory Pro needles are a lot more tapered than the stockers. And, I didn't think you could use other washer(s) with the Factory Pro ones.
I am going to ride the SH for the next couple of days to see if it runs richer with warmer temps and more humidity. Otherwise, I'll back the needles off to spot #2, and adjust the Pilot Screws for the air-fuel ratio to see if I can get it right.
Pookbe
May 31, 2007 10:36 PM
Radiaoktiv
Jan 31, 2007 06:17 AM
Speed_Demon
Dec 26, 2006 11:16 AM
skinnyj
Nov 13, 2006 12:19 PM
BooYeah
Aug 3, 2005 01:04 PM
