Bike wont start
Old Mar 25, 2007 | 09:21 PM
  #31
My lawnmower has a Honda engine in it too! Contaminated gas is good for cleaning dirty parts and tossing it out.
Old Mar 25, 2007 | 10:10 PM
  #32
lovemyhawk's Avatar
lovemyhawk is on a distinguished road
Maybe your jets are clogged up in yer carbuerator. Happens in my 4 wheeler all the time...
Old Mar 26, 2007 | 05:47 AM
  #33
ali_squidz's Avatar
shouldnt it start with starting fluid even if the gas is bad? we shot the starting fluid in the carbs with the tank off and no fuel going to it. Maybe the jets are shot?? we will just chuck the gas.
Old Mar 26, 2007 | 07:27 AM
  #34
ali_squidz's Avatar
is there any way to test those ignition modules and computers?
Im on the phone with the dealer right now and they say that I should replace the plugs and gas. He thinks they will do the trick. Nice helpful guy FYI. Jeff at Hitching Post Coon Rapids, Mn. 763.421.8701
Old Mar 26, 2007 | 10:26 AM
  #35
Yeah, you should be getting at least some kind of fire using the starting fluid. Have you done a compression test?
Old Mar 26, 2007 | 11:00 AM
  #36
gboezio's Avatar
plugs may be bad now, too much fuel and it won't fire it got to come close to stoic to fire like between 10:1 and 17:1, too much fuel at once and it's flooded
If you can get a timing gun it may provide additional infos if all else fails.
Old Mar 26, 2007 | 12:00 PM
  #37
ali_squidz's Avatar
it has compression. I dont know how much it is supposed to have but it's definately kickin. I dont have a manual so I cant tell ya what its supposed to be at.
I found plugs in town and I am going to get them tonight. The bike is at my parents and thats about a half hour away so I probably wont be able to get to it tonight.
We have a timing gun over there. How are ya gonna do that if you cant see any kind of crankshaft?
Old Mar 26, 2007 | 06:35 PM
  #38
gboezio's Avatar
Just hook up to the front cylinder and open the frontmost plug on the left engine cover, you should see a F close to the mark but I doubt that it could be the problem, new plugs, new gas, drain fuel bowls, hook up the fuel tank and do a burnout
Old Mar 27, 2007 | 04:16 PM
  #39
ali_squidz's Avatar
k thank you.
Old Mar 31, 2007 | 10:38 AM
  #40
ali_squidz's Avatar
Well the bike has too much spark. It sparks like 5 times every revolution. Do you guys think thats the computer box thing or the pulse generator?
Old Mar 31, 2007 | 01:09 PM
  #41
SuperHawkins's Avatar
......? I really don't think you can have too much spark.....CDI and multi-strike boxes for cars are on the market for a good reason
Maybe your plugs are just fouled beyond even trying to spark... If I don't wanna spend any money but have a hard start on something, I pull the plugs, scrub them off lightly with a soft-metal brush, like brass....dip it in some gasoline, and reinstall. The gas will release vapors as it dries and gas vapor is very prone to flash-combustion.....sometimes it gives it just enough kick to get it started so the motor can help to clean the plug up and keep it good.
Old Mar 31, 2007 | 02:05 PM
  #42
ali_squidz's Avatar
this is with new and old plugs. already cleaned the plugs off too. no difference. its firing but at the wrong time.
Old Mar 31, 2007 | 04:05 PM
  #43
gboezio's Avatar
I would suspect that the pulse generator is bad, can you get a multimeter with a peak hold function ?? Hook up the multimeter to the pulse generator and crank the engine over, you should read 0.7 V as a minimum peak value. Check for correct positioning.
Edit : if you want to check from the connector box test the yellow/white and yellow terminals.
Good luck these problems sucks...
Old Mar 31, 2007 | 04:06 PM
  #44
ali_squidz's Avatar
thanks a ton man. Ill send that to my dad right now!!!
Old Apr 1, 2007 | 04:09 PM
  #45
ali_squidz's Avatar
Thanks to GB, and the free online manual that you guys had linked, Dad and I tested the pulse generator. Thats working correctly. We found an ICM on ebay for $75. We ordered that up. Should have an answer here really quickly!
Old Apr 5, 2007 | 06:09 AM
  #46
ali_squidz's Avatar
Dad put it in last night and the bike started with a spray of starting fluid!!! YAY!!!!
Old Apr 5, 2007 | 11:29 AM
  #47
Randman's Avatar
Moderate-whore
Excellent, Now you just need to get rid of the shitty weather!! LOL
Old Apr 5, 2007 | 12:56 PM
  #48
ali_squidz's Avatar
Yup, and I am waiting for the rotors that got bent in the wheel chauk when it fell over in the trailer, and the undertail that is completely broken to bits.
This is the undertail...
Location Date Local Time Description
BUFFALO,
NY, US 04/05/2007 9:27 A.M. DEPARTURE SCAN
Old Apr 7, 2007 | 05:57 PM
  #49
ali_squidz's Avatar
its alive and running great!!!!!!!!!!!!!!!!!!!!
Mr.Lojo
Feb 7, 2015 02:48 PM
supertrooper
Mar 25, 2013 01:35 PM
YLTO-Superhawk
Mar 15, 2012 08:50 PM
six6nine9wpk
Aug 11, 2010 07:33 AM
Tonyzz
Mar 29, 2006 01:20 PM
