bike is having major electrical issues!?
Old Apr 9, 2014 | 08:24 AM
Myhairym0nk3y's Avatar
Myhairym0nk3y is on a distinguished road
So i just upgraded the front turn signals to flush mount led and also side mirror with built in led turn signals. Since then I'm blowing the turn signals fuse non stop and now losing my tachometer on and off. Not to mention after riding for over 30 min I turn the bike of and it has a dead start? If I jump it with another bike it will fire right up. Anyone know the issue and if you do a link to a Web site with detailed iinstructions on how to test the faulty areas before I go replacing the voltage regulator and the stator?
Old Apr 9, 2014 | 08:37 AM
It's likely one of two things:
1) Faulty R/R (voltage regulator). It fails often on these bikes as they get older and had inferior technology to begin with. You can read Tweety's Mosfet R/R thread to learn how to upgrade this part. It is not likely the stator, so don't go down that road (yet).
2) Bad wiring of the turn signals. Did the issues happen immediately after this install? If so, I'd check your connections carefully on the signals and the wires leading to them. A shorted circuit could blow fuses or maybe even draw from the battery.
I have a feeling it's number 1. When the bike is running, check the voltage across the battery terminals (at idle and at higher rpm's). If it's too high or too low, then you know what the issue is. Too high of voltage will blow fuses and too low of voltage obviously doesn't charge the battery correctly. A faulty R/R can cause both.
Old Apr 9, 2014 | 08:45 AM
The turn signals worked fine for about 2 weeks after install. Now all these issues are going on at once. At idea the bike sometimes hits hard like it lost all voltage for a split second and sometimes will still run other times will die
Old Apr 9, 2014 | 08:58 AM
Wicky's Avatar
Old Apr 9, 2014 | 10:28 AM
^ Yep, sounds like your R/R. Replace it pronto, before you get stranded or do damage by overcharging. Replace it with a MOSFET unit if at all possible, and it won't happen again.
Old Apr 9, 2014 | 11:45 AM
scottiemann's Avatar
Originally Posted by Wicky
Lol... ****
Old Apr 9, 2014 | 12:03 PM
My vote is R/R as well
Old Apr 9, 2014 | 01:01 PM
Do you have a multi-meter? If so it is easy to test the components before you replace anything.
While it is more than likely the R\R, I hate just throwing parts at a problem.
If you have a meter, what is the voltage of the battery with the engine off?
Then get the reading for idling and at around 3K RPM.
Then to check the stator take a resistance reading on the 3 legs.
Don't worry too much about the Ohm reading except to make sure all 3 read the same (or very close)
Old Apr 9, 2014 | 02:51 PM
Lol... ****
HAHAHA that's priceless!
Old Apr 9, 2014 | 03:12 PM
That was my reaction when I pulled it off my bike and noticed that ****
Old Apr 9, 2014 | 03:15 PM
+1 Do it right and save yourself agreevation
Old Apr 9, 2014 | 05:18 PM
What is this mosfet and do any of you have a link on where to buy it and is this solution just as easy as plug and play? Or I'd there modifying that needs to be done
Old Apr 9, 2014 | 06:11 PM
jerryh's Avatar
Search hairy. Great info here
Old Apr 9, 2014 | 07:02 PM
Wait, hold on... that was the actual stock R/R taken off your bike? I seriously thought someone photoshopped that **** on there!
Old Apr 9, 2014 | 07:39 PM
Originally Posted by Myhairym0nk3y
What is this mosfet and is this solution just as easy as plug and play?
Depends on where you plug it.
Old Apr 10, 2014 | 01:33 AM
Got me the first time too, mine didn't say that.
Old Apr 10, 2014 | 06:53 AM
comedo's Avatar
Dear Hairy,
Check MOSFET Regulator/Rectifiers - The Why & The How in the Knowledge Base. All the answers are there and do as 8541Hawk and NHSH suggest. Welcome aboard.
Old Apr 10, 2014 | 07:40 PM
Thanks guys I got some reading to do
Old Apr 13, 2014 | 08:00 AM
So i found the issue you where all.right it was the R/R I was out riding yesterday and my friend screams your *** end is smoking like crazy! Sure enough the R/R went up and took the wires and the harness with it...
Old Apr 13, 2014 | 10:50 PM
It's not the first time we heard that here. Since you're posting this, I assume your *** did not light a fire?
Replace some wires, get a couple new connnectors (unless you hardwire it), a MOSFET R/R and you'll be ready to rock the Superhawk again. Unless the R/R took out other stuff with it (guages), which I really hope didn't happen.
Old Apr 15, 2014 | 08:35 AM
Didn't we tell you? **** it is ;-), you could have saved yourself money and aggregation, but what's done is done, if the harness is beyond repair, just get a new one, I hope you didn't damage other components, these R/R's have a tendency to kill more than just the harness when they go this way, so check for the rest.
Old Apr 15, 2014 | 08:44 AM
+1 to that
Mine killed my tach and after attempts to fix my tach(blown resistor) to no avail, further investigation has pointed to it killing the ICU...
Old Apr 15, 2014 | 09:27 AM
Well now at least you don't have to test voltage to see if it's your r/r. And you got to leave an awesome contrail as a final farewell to the unit.
living the dream 1122
Apr 5, 2014 01:15 PM
Blueracer
Oct 31, 2012 06:43 PM
SinfulFuture
Dec 26, 2011 12:22 PM
Shortlived99
May 27, 2008 09:12 PM
nuhawk
Aug 21, 2007 07:11 AM
