APE CCT leaking?
Old Jun 26, 2009 | 08:10 PM
barrysuperhawk's Avatar
barrysuperhawk
APE CCT leaking?
Had a set of APE CCT's put on and now I am noticing a small but steady ooze of oil off of the rear CCT. It's comming out the threads themselves [if that makes sense]. The actual CCT and locknut are tight, and there is no leakage around the gasket.
Since this is dripping oil within inches of my rear tire, I am concerned with this, but I am not real sure how to "fix" this without F'ing anything up..
Old Jun 26, 2009 | 08:26 PM
Gregw's Avatar
I had the same thing recently. Loosened the nylock while keeping the bolt from turning. Once I had enough space, I slathered a little Hylomar (non-hardening gasket sealer) on the threads and re-tightened the nylock. So far so good.
Old Jun 26, 2009 | 08:48 PM
Later APEs have an o-ring between the locking nut and the cct. But even that doesn't always prevent the leak.
Old Jun 26, 2009 | 09:01 PM
996's Avatar
996
v-twin4tmfw
996 is on a distinguished road
Put the rear cylinder to top dead center (look at the timing marks by pulling off the little round cover on the left side of the engine with a hex wrench and get it to show RT by spinning the rear tire in 6th gear.) , pull off the CCT and wrap the adjuster bolt with teflon tape and reassemble. Irrs195 showed me that mine was leaking, as I didn't even see it. Mine has the o-ring, but it still leaked because the o-ring doesn't seal on the thread that good.
Old Jun 26, 2009 | 09:20 PM
Easier way - Back off the locknut and smear a little RTV on the threads up against the body of the CCT. Tighten locknut. I replaced my o-ring but it still didn't help. This was the only easy way I could find to stop the drip...and it worked!
Old Jun 27, 2009 | 09:14 AM
98ILVTR's Avatar
So before I install mine shortly, which procedure should I follow? Teflon tape or RTV?
Old Jun 27, 2009 | 01:38 PM
Either one should work. For initial install try the teflon. If it doesn't work then the RTV is a good solution without having to remove/reinstall.
Old Jun 27, 2009 | 03:17 PM
little squirt's Avatar
little squirt is on a distinguished road
hot damn, almost posted a thread about this, thanks for the info
Old Jun 27, 2009 | 04:24 PM
lrrs195's Avatar
swinging member
lrrs195 is on a distinguished road
A.P.E. recomends using teflon tape, had the same problem with mine.
Old Jul 7, 2009 | 12:33 PM
opsmgr's Avatar
opsmgr is on a distinguished road
I didn't put either on my APE tensioner, but mine is the later type, with the O ring. I only have it on the front cyl too, the rear auto tensioner is ok (full of oil)
Paul.
Old Jul 11, 2009 | 01:37 PM
badboyrr's Avatar
Thumbs up leaker
same happened to me, RTV worked for me.
Old Jul 11, 2009 | 02:27 PM
haknslash's Avatar
Just get some gasket material. I wasn't confident in the design of the CCTs without a gasket for metal to metal contact surfaces. The gasket material is real cheap and you just trace the profile of the CCT and then cut it out. Much cleaner than using silicone.
Crashrat
Oct 11, 2012 08:25 PM
SloBlue
Dec 24, 2011 03:44 PM
CyberBeast
Dec 13, 2008 03:14 PM
khanawalt
Apr 16, 2007 06:57 PM
CyberBeast
Mar 17, 2007 03:08 PM
