Anyone added a second fan?
Old May 19, 2008 | 10:47 AM
Tysonb's Avatar
Tysonb is on a distinguished road
I have an 05 Superhawk that I just bought with 0 miles about 2 weeks ago. It runs warm, which I read is somewhat normal. I was inquiring about adding a fan to the second radiator. has anyone done this? Also what about lower temp sending units to turnt he fans on at 180 or so?
Thank you in advance for the help, and you have an awesome forum going
Old May 19, 2008 | 11:08 AM
RickB's Avatar
I started down this road but the issue is getting something that will screw into the threaded hole in the radiator which I am guessing is a metric thread and the automotive ones are probably standard. They do have the adjustable ones with a sensor bulb that I have seen guys sneak under the radiator hose in cars and they didn't seem to leak so you may be able to go that route or attach it to the exterior of the rad or in the fins. For now I just ran a wire that provides a ground to the stock sensor wire through a switch mounted under the brake master cyl so I can turn it on manually if its starts to heat up and it will still work normally if you don't touch the switch.
Old May 19, 2008 | 11:30 AM
fuzzuki's Avatar
fuzzuki is on a distinguished road
That's exactly what I was thinking of doing.
I just hate it when the fan comes on in stop and go traffic.
The damn thing blows hot air right at me. Feels like I'm hugging a furnace.
Old May 19, 2008 | 11:51 AM
kai ju's Avatar
Smile Second fan
I added a second fan to mine.................
Sorry, just couldn't resist.
Kai Ju
Old May 19, 2008 | 12:40 PM
RickB's Avatar
That should keep the 'hawk cool
Kai Ju
Old May 19, 2008 | 03:56 PM
Yeah, but you lost all your undeseat storage! ha! Also serves as a rear tire warmer!
Old May 19, 2008 | 11:21 PM
kai ju's Avatar
Underseat storage
Hey Hawkrider, do you have room for two fans under your seat ?
I do.
I also don't get poached by heat coming off the front mounted radiators.
Kai Ju
Old May 20, 2008 | 12:21 AM
Death Cattle's Avatar
use engine ice instead of 50/50 antifreeze in your bike. engine ice makes everything run a lot cooler.
Old May 20, 2008 | 08:35 PM
Up here in NY I use the radiators as hand warmers!
Old May 20, 2008 | 10:22 PM
kai ju's Avatar
Handwarmers
I use Acerbis UNIKO Hand Guards with heated grips......which I can turn off.
In all seriousness, I've been running the underseat radiators for over three years with no problem. I don't get heat soaked from the front mounted radiators and cannot feel any heat coming from the underseat set up. The second fan rarely sees any use even though the primary fan does cycle constantly. ( I'm still looking for the natural airflow solution )
Other than the loss of underseat storage it's been a very successfull mod for me.
Kai Ju
BIG DAVE 03
Jul 7, 2012 11:55 AM
Randman
Mar 1, 2007 07:22 PM
Nanotech
Mar 1, 2007 03:17 PM
