Another R/R failure and wiring question
Old Jul 15, 2005 | 10:10 PM
jhaldin's Avatar
jhaldin
I was stranded a couple weeks ago by a rectifier failure. Running along at 80mph one second and coasting to the side of the road the next. Unplugged the R/R and all the lights and replaced the main fuse with the spare 20 amp headlight fuse. Jumped the starter relay with a pliers and managed to limp home. I found a R/R from a CBR 954 for $10 bucks but it has 8 wires (2 red, 2 green, 1 black , and the 3 yellow) to the VTR's 5.
I assume the reds the black and the yellows are the same but I'm unsure about the greens. I'm guessing tieing the greens to the frame would be appropriate but thought someone here would know for sure.
Anyone....Bueller?
TIA
Jeff
Old Jul 15, 2005 | 10:47 PM
W-O-T's Avatar
W-O-T
I havent tackled this on a bike yet.. but for trucks... mines a hybrid....
I always check continuity of electrical components to see if they are doubled up out of the compnent... that way I know if I can illiminate one...
Old Jul 16, 2005 | 05:36 AM
penst8grad's Avatar
penst8grad
Re: Another R/R failure and wiring question
Read this, should have the answer to all your questions. Just don't use another Honda unit!
Old Jul 16, 2005 | 08:27 PM
jhaldin's Avatar
jhaldin
Thanks Guys. I went out to put it together this afternoon and realized I'm an idiot. It's the black wire that's the odd ball on the new rectifier. There is continuity between the 2 greens and between the 2 reds. The black wire is maybe 18 gauge where the others are 14 gauge. I grounded the black to the chassis. When I cranked it up I was reading 16.5 volts. Pretty hot. I'm wondering if this black wire is some sort of voltage sensing wire.. If anybody has any idea I'd appreciate the input.
Old Jul 30, 2005 | 02:34 PM
does anybody know if this r/r will work for the super hawk?
looks beefy but i'm not hot on electrical stuff... so i dont know if it's gonna put out too much power or what.
thanks for the help!
daniel
Old Jul 30, 2005 | 02:35 PM
sorry... double post....
Old Jul 30, 2005 | 07:57 PM
superbling's Avatar
You need to find out what kind of connector it has. Many use 6 and FI bikes use upwards of 8 connections.
Old Jul 30, 2005 | 08:22 PM
well the connector looks almost identical... he's supposed to send me a head on pic soon.. i'm more worried about the internals...
Old Jul 30, 2005 | 11:29 PM
do the new honda units have cooling fins?
Old Jul 31, 2005 | 12:01 PM
jschmidt's Avatar
jschmidt
Mine was easy to diagnose:
I'm going with the updated Honda unit. If I get bad service from that, I suppose I'll look at cobblint. I was also thinking about adding press in vents to the cowling.
Old Jul 31, 2005 | 05:06 PM
caffeineracer's Avatar
caffeineracer
Here's the old and new Honda VTR regulater/rectifiers
Haven't had a problem since replacing it with the updated unit.
Old Aug 23, 2005 | 09:00 PM
jhaldin's Avatar
jhaldin
An update for anyone searching the archive. I managed to find a wiring diagram for the 954. The black wire is a voltage sense wire and requires a switched 12 volt source to regulate properly. I spliced into the taillight circuit and now have 14.2 vots at idle. Much better.
Big_Jim59
Dec 30, 2014 08:40 AM
DavidEW
Aug 7, 2014 07:14 PM
Grizz
May 31, 2010 10:09 AM
99Hawkboy
Apr 21, 2010 02:20 PM
LineArrayNut
Oct 28, 2008 04:39 PM
