Another CCT Question
Old Feb 6, 2010 | 12:40 AM
super duper hawk's Avatar
super duper hawk is on a distinguished road
Has anyone made a manual CCT out of the stock CCT? If so will it work as good as an APE CCT? If you have, can someone walk me through the steps? Or if someone has some home made CCT's or APE CCT's for sale cheap please PM me.......thanks
Old Feb 6, 2010 | 03:43 AM
Yes...
Have a look here... https://www.superhawkforum.com/forum...hlight=diy+cct
Old Feb 6, 2010 | 10:49 AM
Thanks Tweety I will check it out.......
Old Feb 6, 2010 | 01:57 PM
Mark S's Avatar
Mark S is on a distinguished road
Take a look at this thread.
https://www.superhawkforum.com/forum...light=cct+redo
Having looked at the attempts at making the stock CCT's safe, I think this is the only
way that makes sense. Look at the way the CCT's operate and you will see the bolts
will not hold the cam chain tension if the spring breaks. The sleeve is easy and secure. The CCT cannot retract past the sleeve after a spring failure.
Old Feb 6, 2010 | 10:04 PM
So its best to go with the APE CCTS ????
Old Feb 7, 2010 | 09:39 AM
Mark S's Avatar
Properly installed the APE CCTS will be the best.
Old Feb 7, 2010 | 09:50 AM
Properly installed a manual CCT is best... If it's an APE or another manufacturer or DIY work is completely irrellevant...
Various schemes to lock the standard CCT is just patch work...
I'm running original CCT's that I drilled out the way described in the thread above... This is completely equivalent to the APE's... No possibility of them failing... The cost is whaterver a few bits cost you at the local hardware store and some time...
Ie an M8 (or 5/16 for you metric challenged) wagonbolt and a nyloc-nut as adjustment lock plus a standard nut with a locking pin to use as adjuster... Much cheaper than a set of APE's... And all you need is a good drill and a the tools to cut new threads... Still cheaper than APE's if you haven't got them...
Old Feb 7, 2010 | 11:33 AM
Bytes's Avatar
Bytes
Bytes is on a distinguished road
Another thanks Tweety. I did some searching on CCTs before I joined the forum and was overwhelmed at how may posts show up. I am definitely going to do your mod to the stock ones.
Renderw
Oct 2, 2012 04:52 PM
geekonamotorcycle
May 24, 2011 01:43 PM
mikstr
Jan 17, 2011 01:34 AM
Eddie
Aug 22, 2009 02:48 PM
miken996
Jan 7, 2006 11:59 PM
