Altitude and jetting?
Old May 12, 2009 | 03:35 PM
sumthin_major's Avatar
I am moving to greeley colorado this weekend and was wondering what jetting I needed for a 6000 ft elevation. I will put a K&N filter in and I have debaffled pipes. Suggestions?
Old May 12, 2009 | 03:59 PM
Circuit_Burner's Avatar
guru of things sparky
If it was running kinda lean, it would probably run better.
Otherwise, if jetting was spot-on at sea level, you will need to lean it down a bit.
Old May 12, 2009 | 04:50 PM
BeerHunter's Avatar
Slacker
More air or less fuel
If memory serves me correctly, other members have reported a rich condition with stock main jets at 6,000'(carbon fouled plugs)... a condition which was remedied simply by installing a K&N air filter. I would think that aftermarket slip-ons would really help this as well. In my experience with this bike, modified stock mufflers yield a very small increase in exhaust gas flow. You could be OK with what you already have done, assuming the carbs have not been re-jetted.
Old May 12, 2009 | 06:57 PM
thanks for the input.
Old May 12, 2009 | 07:08 PM
If you've specifically tuned for sea level then you're going to have to make changes to all three circuits of the carbs - mixture screws, needle height, and main jet. For stock carbs, a simple adjustment of the mixture screws will get you by, but changing mains to one size smaller is highly recommended.
mikecronis
Dec 22, 2007 12:34 PM
DannyTsi
Jun 13, 2007 04:31 PM
Galaxieman
May 7, 2007 06:45 PM
Auron
Mar 17, 2006 09:43 AM
mhsanger
Aug 3, 2004 10:28 AM
