alot of work ahead
Old Feb 28, 2012 | 12:20 PM
saige's Avatar
the boss
alot of work ahead
ok,i have been stocking up on parts for a bit know.been limping the bike along until i have enough stuff to do a good run thru on the bike.
my first question is,i have racetech springs and rebound and compression valves,seals,everything for the forks except a brace.
what fork oil should i be using in the rebuild.
bike is stock and i weight 175 if that helps any.
the front end will all be done up,changing bearings too,any little tips on that would help too.
Old Feb 28, 2012 | 12:46 PM
geekonamotorcycle's Avatar
txt me when you take off the forks. I would love to lern that process for my own bike.
Old Feb 28, 2012 | 12:56 PM
saige's Avatar
the boss
not a problem,i have to do a little research,but overall,it doesnt seem so bad.just gotta make sure i take measurements before taking apart.
so we both will be learning together lol
Old Feb 28, 2012 | 01:00 PM
speedkelly@aol.com's Avatar
It's pretty straight forward. Best advice is to have a clean work bench, take your time and keep all parts clean at all times. Loosen Forks cap before you remove the forks. Becareful removing the allen head bolt on the bottom of the forks. make sure when you install the fork seal everything is super clean.
Good luck, it's a nice day long projec, if it's your first time.
Old Feb 28, 2012 | 01:04 PM
saige's Avatar
the boss
ok,thanks for the tips.
yes,this is first time.i will not be doing it today,still waiting on other parts.im gonna do one big run thru on the bike,from screws,to carbs,seals,bearings etc etc....i have alot of parts.
the body will be the last thing.
i will attempt to do the forks myself,but,we have a resident suspension guy,so if i get in trouble,i will be able to take it to him.
Old Feb 29, 2012 | 09:46 AM
Another tip... Before you loosen the fork caps, also loosen the allen bolt in the bottom of the forks... Don't remove it, it will leak oil, but loosen it... If you try to do it in the other order, it will probably just spin... A real PITA... I's much, much easier to get both parts moving before you drop the forklegs... Will probably spill a few drops, but it's well worth it...
Old Feb 29, 2012 | 09:57 AM
saige's Avatar
the boss
ok,will do.thanks
Old Mar 18, 2012 | 06:05 PM
saige's Avatar
the boss
so would anybody know what weight fork oil i should use.
i will be doing this very soon,in the next couple of days.
from what i have researched,140mm is a good starting point or does it really depend on other factors.
Old Mar 19, 2012 | 12:11 AM
Stephan's Avatar
I have racetech springs, compression valves, tapered rebound rods. 5W oil and 130 mm level works very good.
Old Apr 12, 2012 | 10:24 AM
saige's Avatar
the boss
well,today is the day,been working on the bike the last couple of days,got alot done.
so does everyone agree with 5w oil and 130mm
the bike most likely wont see track days,but i do ride it hard at times.
so would this be correct to go with.
Old Apr 12, 2012 | 07:20 PM
saige's Avatar
the boss
how do you remove the bolt from the compression valve without damage.
correll1000
Mar 12, 2011 07:11 PM
havoc7685
Sep 16, 2010 01:13 PM
Lilbitz909
Jun 6, 2007 10:02 PM
mikstr
Apr 7, 2007 02:44 PM
Stumpy
Mar 10, 2007 05:04 PM
