All gauges stopped working.
Old Sep 5, 2014 | 01:55 PM
icwe2's Avatar
icwe2 is on a distinguished road
98 superhawk everything was going good riding into dr when I look down and all 3 gauges are not working speed/temp/temp and no neutral light or kickstand light. Sitting at dr office now wondering where to start to track down this problem. Anyone had this issue before?? Any suggestion would be great. Thanks
Old Sep 5, 2014 | 01:58 PM
jscobey's Avatar
Search around you'll find the answer
If you type in "gauges not working" you'll find a ton of threads on this. Hint: its your R/R
Old Sep 5, 2014 | 05:04 PM
CrankenFine's Avatar
did you already check the fuse?
Old Sep 6, 2014 | 04:08 AM
dudeitscristhian's Avatar
dudeitscristhian is on a distinguished road
jscobey is on the right track. My bike began shutting the gauges off during a ride and then left me stranded as the R/R failed.
Old Sep 6, 2014 | 05:42 AM
A digital volt meter is your friend that and a 12vdc test light.
Start with a key off battery voltage reading, then key on, then key on running.
Physically inspect the R/R charge wire plug this is often found melted due to high resistance.
If none of that is conclusive then you can move on to other inspections and tests.
Old Sep 6, 2014 | 08:07 AM
Replace you regulator rectifier. Tons of info on here, and expect to get stranded soon if you keep riding.
Test voltage across the battery while bike off and bike running and report finds.
Assume your battery needs a charge and buy a float charger since you will need one as a bike owner anyway.
Old Sep 6, 2014 | 02:24 PM
pressguru's Avatar
pressguru is on a distinguished road
Same exact thing happened to me. Replace your regulator. I found one modified on eBay for 49$. I also replaced the pin connector and pins that plug in as they were damaged from the heat. The new regulator was encased in a aluminium fin d design to help dissipate heat.
Old Sep 6, 2014 | 04:54 PM
pressguru? Off-topic for a minute, any chance your are in the printing industry?
Old Sep 8, 2014 | 01:26 PM
icwe2's Avatar
It was the fuse...I replaced that and just again today while riding home lost all gauges again.... Bike is still running fine would it be the r/r that is starting to fail on why my fuse keeps blowing?
Old Sep 8, 2014 | 02:02 PM
thetophatflash's Avatar
Yep
Old Sep 8, 2014 | 09:35 PM
A failing RR will cause a whole slew of wacky issues. Turn signals, headlight, fuses, dead battery.
I have pulled over to help many bikers broken down and a bad RR is the issue more than all other issues combined. It happened to me twice, once had to push it for miles in 98* temps.
The funny thing is, everyone tries to push or jump the bike & tries to keep revving it to keep it from stalling but since its not chargiing that only makes it worse. (sucks more power for spark from an empty system).
Do the check of voltage across the battery running and not. Then rev it a bit to see what happens.
red02vtr
Jul 26, 2012 01:02 PM
superman_006
Jun 30, 2009 05:46 AM
Paradisd
Apr 24, 2009 02:35 PM
quakefiend420
May 13, 2008 05:18 AM
ChicknHawk
Mar 28, 2007 06:00 PM
