air adjustment screw tool
Old Dec 15, 2012 | 06:09 PM
twist's Avatar
Motion Pro Bit D shaped for use with 08-0229 90 degree tool (SKU 08-0242)
this might be the thing to use on my flexible shaft screw driver to adjust the D shaped air screw.
Screwdriver Set 22 in 1 Flexible Duragear - Amazon.com
Old Dec 15, 2012 | 07:20 PM
You can try it but in my experience, there is not much free room in there. I have this and it barely makes it (but does the job)
Motion Pro Pilot Screw Adjusting Tool 08-0119 : Amazon.com : Automotive Motion Pro Pilot Screw Adjusting Tool 08-0119 : Amazon.com : Automotive
I have a flexible shaft screwdriver but it just couldnt quite do it. Anger didnt help.
Old Dec 20, 2012 | 07:05 PM
nath981's Avatar
You can try it but in my experience, there is not much free room in there. I have this and it barely makes it (but does the job) Motion Pro Pilot Screw Adjusting Tool 08-0119 : Amazon.com : Automotive
yo joe, is this tool have a "D" or flat screwdriver end?
thanks,nath
Old Dec 20, 2012 | 07:26 PM
Its a flathead but its no problem reaching in with a little dremmel wheel to cut a slot into that oh-so-soft metal (of the screw) so it works great.
Old Dec 20, 2012 | 08:02 PM
nath981's Avatar
thanks for the quick get back. Already got the screws slotted. I'm ordering it now. Appreciate the info. and the link. Didn't know if it would work cause i already have a remote screwdriver, but the turn is too shallow so it's a no go.
I gotta do some merge work to do on my 2 into 1, then i'll be using this tool.
thanks again
Old Dec 21, 2012 | 04:08 PM
Yep, the $130 Honda specialty tool is pretty much the only one that will work with the carbs still installed (and mixture screws NOT slotted).
Old Dec 21, 2012 | 04:24 PM
RWhisen's Avatar
Former Superchicken Owner
I managed to get one of those off Ebay several years ago for about 100 bux. It has been worth the purchase!
Old Dec 21, 2012 | 04:36 PM
Worth the purchase? $100 vs $23? Seems economicly undesireable. Took me like 5 min to slot the screws. I will stick with $23 & use the $77 spare bucks for Christmas presents.
Old Dec 21, 2012 | 05:12 PM
RWhisen's Avatar
Yeah but I didn't have to pull the carbs to do it AND I can slap it on there any time and tweak them without hassle!
Old Dec 22, 2012 | 02:40 PM
cybercarl's Avatar
Unfortunately there is no easy access. I use the more expensive Motion Pro screwdriver and that is a struggle. Especially on the rear cylinder.Motion Pro 90-Degree 1/4" Hex Driver- Tool Time- Motorcycle Tools
In an ideal world I would like some fuel screws with a twirled **** that I can turn by hand. I have found some for quite a few for other bikes, mainly HD's and 2strokes, but not the VTR CARBURETOR - FUEL SCREWS - Zip-Ty Racing Products
Relavent thread here https://www.superhawkforum.com/forums/general-discussion-30/carb-mixture-thumb-screw-28832/#post338413
I will find out what the thread pitch is one day and maybe get some made up. I am constantly tweaking and playing with the carbs and not having easy access to the A/F adjustment frustrates me.
twist
Nov 27, 2012 01:52 PM
Fox
Dec 14, 2010 11:46 AM
VTRsurfer
Jun 2, 2010 02:44 PM
99Hawk
Sep 15, 2005 09:55 AM
99Hawk
Apr 30, 2005 06:01 PM
