95 VFR Clipon's
Old Apr 14, 2008 | 06:44 AM
StoneJrW's Avatar
StoneJrW is on a distinguished road
95 VFR Clipon's
I recently got a pair of 95 VFR Clipons and have been searching/reading threads involving installation. I have a question. Do I need to replace my stock lines with longer ones. Ive found some say you need to and some say you dont. Which is right?
Old Apr 14, 2008 | 08:11 AM
FL02SupaHawk996's Avatar
Fastest Color
Stone, I'd take the opportunity to put on some braided lines if it were me bro. I have braided lines now with stocker brakes and they are strong!
Rick C.
Old Apr 14, 2008 | 10:10 AM
Besucher98's Avatar
Besucher98
I agree. You may be able to get away without but the fit may end up being tight without and re-routing. I changed to braided afterI already changed becuase I experience restricted movement in stock trim. After re-routing it was OK but I still wanted to change for my own piece of mind.
Old Apr 14, 2008 | 11:21 AM
superbling's Avatar
It should only take a matter of minutes to find out. I all ready had SS lines too so I can't say for sure if the stockers are fine.
If it's very close you can look at re-routing the line or removing any tie down points that can restrict free play. Another thing I've done on other kinds of bar mods is to change the cable route at the master cylinder to a more downwards path. On one particular setup, I even ground off the m/c tab to get the best angle but that's something you shouldn't have to do on this mod; just pointing out there is more than one way to skin a cat.
Old Apr 14, 2008 | 11:59 AM
StoneJrW's Avatar
OK Thanks. I'll Do the braided line upgrade. Searching it looks to be many choices. What type do you guys have. Length? Are there supposed to be caps on the bleeders? I dont have any. My fluids are DARK!!!!!!!
Old Apr 14, 2008 | 08:01 PM
Mr Toad's Avatar
Deus vult!
Mr Toad is on a distinguished road
I just completed the VFR bar mod and with stock lines I had to unbolt the square brake line junction box from the lower triple and adjust the two throttle cable guides. With that done there are no clearence issues turning the bars lock-to-lock. Good luck.
Old Apr 14, 2008 | 08:51 PM
102dals's Avatar
I concur with Mr Toad....No need to change brakelines, just unbolt the junction box. I noticed a slight difference with Kevlar lines, but not enough to spend full price (I got mine on Ebay really cheap).
BTW, 94-96 VFR bars are the best ones for the $$...did you get end weights with them (stockers won't fit)? Solid aluminum & oh so pretty. Honda should've put them on to begin with.
Old Apr 15, 2008 | 04:25 AM
Fastest Color
Bleed those brakes and clean out reservoir if needed and refill system with new fluid....you'll notice the difference
K30
Jul 20, 2011 05:32 PM
skoshere
Jan 15, 2009 10:50 AM
01SuperChicken
Jan 12, 2009 01:22 PM
CNI Dawg
Jan 18, 2006 09:09 PM
wormeater
Jun 8, 2005 02:11 PM
