2003 CA Superhawk - Where are the CA Parts
Old Aug 12, 2022 | 03:41 PM
Tortalover's Avatar
Tortalover is on a distinguished road
I removed the pair system and plugged everything up, but I have reading about some canister for the oxygen or blah blah blah that also has to be removed. Where exactly is that located on the bike? Is there anything else that I need to remove? I want to make sure I remove everything that is CA smog related. I have plugged up all and rerouted hoses as suggested in these posts. Can't wait to turn this bad boy on.
is this the O2 canister?
Thank you.
Old Aug 12, 2022 | 05:05 PM
Originally Posted by Tortalover
I removed the pair system and plugged everything up, but I have reading about some canister for the oxygen or blah blah blah that also has to be removed. Where exactly is that located on the bike? Is there anything else that I need to remove? I want to make sure I remove everything that is CA smog related. I have plugged up all and rerouted hoses as suggested in these posts. Can't wait to turn this bad boy on. Thank you.
I believe it's on the front of the bike, somewhere. This is what it looks like. https://www.ronayers.com/oemparts/a/.../evap-canister
It would be much better for you to keep all of your posts in one thread.
Old Aug 13, 2022 | 05:50 AM
Might have air in the cooling system.
There's a forum member who sells brass replacements for the choke. Let me search that for you.
https://www.superhawkforum.com/forum...ss-made-33364/
The factory service manual is a free download.
https://www.superhawkforum.com/forum...-manual-11365/
Old Aug 13, 2022 | 05:52 AM
The engine coolant shot out the reserve overerflow and a loud pop when I shut the bike off. I'm trying to find the canister (not sure if that has anything to do with it), and figure out what I missed. The only that I screwed up was breaking the choke cable at the back. Can some take a pic of where this canister is supposed to be. Was passing 200 when I shut it off. Any ideas? Thanks.
That's a coil bro... Spend some time with the manual.
tapatio
Aug 31, 2016 06:48 AM
tewolf24
Jun 14, 2015 06:55 PM
alientestsubject
Sep 6, 2010 01:55 PM
PRTSMN
Feb 26, 2008 03:29 PM
nuhawk
Mar 23, 2007 04:56 AM
