2 Questions, gooders to!
Old Jul 3, 2006 | 10:19 PM
dustinwild's Avatar
dustinwild
first: While riding full throttle excellerating up to 9000rpm. it feels like the bike starves for fuel, or clutch is slipping, but only it higher gears. Petcock dumps out the gas, so I doubt it is that. Bike runs awesome right to redline in lower gears. So, it's hard to diagnose... I can't find a mechanic that will test it for me because it only does it in 4th 5th and 6th. So, I really can't hear what it is doing, all I know is it feels like it misses for a 1/2 sec, then kicks in. It just keeps on kicking in and out. I can't figure this one out.
Second: Went for a nice long ride, well, about 1 1/2 hours. Rode down a street that was very slow, and came to an intersection, and some punk in a car revved his engine at me... So, I just wanted to show him what he was up against, so I launch in 1st to redline, hit second, and braked for the next light. Pulled the clutch, and it died. Then I couldn't get it running again without thottle. Only firing on one cylinder. Not sure which one, or anything yet, as I just got home, and it is really late, but anyone have any ideas on this one? Just a fowled plug? they are brand new, about 300km on them. Not sure where to look first. Just want some advice. Please help! I know it was getting gas, as I could smell the unburned fuel in the exhaust.
Old Jul 4, 2006 | 09:17 AM
Lemme guess on the second one:
You just fill up on gas when you did the little "race". More than likely you dumped fuel into your tank vent and you need to vent the tank by opening the filler cap. Should run fine after that. Other possibility is you braked really hard at that light. That'll make the bike stall, but it usually starts right back up which leads me to believe it's the first case.
Old Jul 4, 2006 | 09:44 AM
dustinwild's Avatar
dustinwild
Nope, just after it happened the fuel light came on, rode it to a gas station, and still ran like that, keep in mind, I can smell the unburned fuel in the exhaust. I am thinking it may have fowled a plug when it stalled. But I don't know. I just wanted to see if this has happened to anyone. I didn't think plugs died that quick, unless there was something majorly wrong with mixture, or something like that.
Old Jul 4, 2006 | 06:23 PM
superbling's Avatar
Not a slipping clutch as that would let the engine easily rev but not pull.
Old Jul 4, 2006 | 07:03 PM
vitter's Avatar
vitter is an unknown quantity at this point
find a shop with a dyno, they can check it out in 4th 5th and 6th.
Old Jul 4, 2006 | 07:04 PM
dustinwild's Avatar
dustinwild
My only issue is I am really tight for cash at the moment, so a lot of it I need to do myself. If I can. Speaking of which, I am going out to check the plugs. see if I have a spark.
Old Jul 4, 2006 | 07:49 PM
dustinwild's Avatar
dustinwild
Okay, so it's the front cylinder, have spark when I pull the plug, and hold it against the block, but doesn't seem to fire when it is in the head. I tried different plugs, but nothing. Cold exhaust pipe, wet plug, good compression. I am lost. Any help Please!!
Old Jul 4, 2006 | 09:07 PM
Well, if you've got spark, gas, and compression, then one of the three is out of time. I'm more likely to believe that it's the spark since if it was valves it would run poorly or a valve would hit a piston if out of time far enough. Start there.
Old Jul 5, 2006 | 04:52 AM
dustinwild's Avatar
dustinwild
You cannot adjust spark timing on these bikes. It is fixed, is it not?
Old Jul 5, 2006 | 01:03 PM
Well, yeah, it's fixed, but there's a pickup coil and then there's the ECU which I guess could be sending a bad signal, but I've never heard of that before. I guess anything's possible....
Think maybe there's TOO MUCH fuel?
Old Jul 5, 2006 | 02:19 PM
dustinwild's Avatar
dustinwild
Well, even if there is too much fuel, wouldn't it alteast fire once in a while, or something like that? I guess it is possible.
macarthor
Apr 24, 2007 09:42 PM
supertwinSH
Apr 11, 2007 04:39 PM
Randman
Mar 29, 2007 08:19 PM
bluedog66
Mar 26, 2007 07:47 PM
Erion_squid
Feb 18, 2007 02:34 PM
