1998 VTR intermittent cut out-light dimming
Old Jul 17, 2016 | 04:02 PM
Legion's Avatar
Legion is on a distinguished road
greetings all, I have a 1998 VTR that has a very intermittent cut out, which seems like only 1 cylinder, went through the carbs, which have had previously installed Factory jet kit, replaced the coil packs, still very inconsistent-it does not do the same exact thing always, problems are the same, but its not always at 2000 rpms or when the clutch is pulled in or anything. there is also a problem that I initially thought unrelated, but the headlights intermittently dim for a moment, doesn't always happen and doesn't always happen when the cut out is happening. Wicked perplexed and almost ready for c4... anything would help...
Old Jul 17, 2016 | 05:09 PM
Apocalypse's Avatar
Night Rider
Apocalypse is on a distinguished road
I would look at your R&R it can cause a lot of problems like this
Old Jul 17, 2016 | 07:08 PM
Legion's Avatar
I did replace the regulator in July of 2012 shortly after I bought the bike the battery had swollen overcharging and almost burst it was aftermarket not sure the brand but with big chunky cooling fans to hopefully not have the same problem as the stock I haven't ridden much unfortunately and this probably only about six thousand miles on that regulator I guess versus stripping the bike down to just the wiring harness this is an easier option.
Old Jul 18, 2016 | 01:36 AM
Cadbury64's Avatar
VTR virgin
Maybe check the battery cables are tight at both ends, and that there is no undue corrosion. Also look at the sidestand switch and check it is not loose and the connector is tight.
Old Jul 18, 2016 | 01:52 PM
Apocalypse's Avatar
Night Rider
it could also be your stator going out and not providing ample voltage at all times
Old Jul 19, 2016 | 05:52 AM
Good suggestion. A failed R/R can fry the stator windings.
Old Jul 19, 2016 | 08:45 PM
Cadbury64's Avatar
VTR virgin
It can be tough to diagnose intermittent faults, but if the bike is charging the battery OK then no point leaping into the stator or RR, all those do is keep the battery topped up, but the battery is the source of power for the bike to run. You can quite happily run a bike without the stator or RR even installed, until the battery voltage falls too low. Still it is worthwhile putting a voltmeter across the battery terminals with the bike running and take it up to 5000 rpm, and the RR should be delivering 13.8 - 14.8 volts (or near offer) which will be enough to keep the battery happy.
If the battery itself is nearing the end, you might get the running on one cylinder symptoms, and that could also happen if there is excessive voltage drop due to corrosion of any of the connection points. That would also lead to the lights dimming.
996thehawk
May 14, 2016 10:52 AM
wannabridin
Oct 25, 2014 10:51 AM
0401supercar11
Apr 5, 2011 11:03 AM
kroeninga
Sep 13, 2008 06:52 AM
2005Hawk2006
Sep 14, 2006 11:59 PM
