1998 Superhawk wont start
Old Jan 30, 2010 | 08:42 AM
996HAWK's Avatar
996HAWK is on a distinguished road
Bought the thing yesterday 1-29 - 2010 Backed off trailer wont start .Had a backfire though 25000 miles on bike what could be problem.Does kickstand have to be up? or is it much worse!?
Old Jan 30, 2010 | 09:51 AM
pigwings's Avatar
pigwings
nice introduction to the group
Old Jan 30, 2010 | 09:58 AM
skoshere's Avatar
welcome and check the engine kill switch on the right hand side of the controls
Old Jan 30, 2010 | 10:16 AM
john3012's Avatar
Squided
Oh yeah? That is bad, motor is probably blown. If you are near Atlanta, GA I will scrap the bike for you.
Last edited by john3012; Jan 30, 2010 at 10:17 AM. Reason: Motor is definetly blown!
Old Jan 30, 2010 | 10:43 AM
mhaisten's Avatar
Wrench Bender
There is a whole list of possibilities. Kill switch, side stand switch. Start with the basics. Pull a spark plug and check for fuel and spark.
Stay away from john3012. I'd hate for him to be my doctor..........doctor says your gonna die!
Old Jan 30, 2010 | 10:47 AM
PUSHrod's Avatar
Pretty skinny list of symptoms and attempts.
Assuming side stand down, in neutral, kill sw set to run....start gets pushed and no life.
Stick a VOM on the battery and give out the reading. Less than 12.5 try jumping. More than 12.5 try fresh fuel and full choke.
Still no start? Find out which you don't have...fuel, air, spark.
Big twin, huge carbs cold weather, bad advice, cheap beer, testosterone fever all contribute to problem. Repost when progress is made, please.
Old Jan 31, 2010 | 02:11 AM
996HAWK's Avatar
Had to order sparkplugs will be in tuesday it was running so i hope that solves it.By the way where can i get a tech manual?
Old Jan 31, 2010 | 02:26 AM
REDVTR1000's Avatar
Search this forum for the tech manual. Might i suggest also reading the owners manual
Old Feb 2, 2010 | 02:01 AM
996HAWK's Avatar
Smile
Caught h changing plugs but got it fired right up.What do u use for sparkplug wrench because conventional to wide for hole? Rigged on up .
Old Feb 2, 2010 | 02:23 AM
RK1's Avatar
RK1
Manual download
http://www.superhawk996.net/Honda_VT...ice_Manual.pdf
Old Feb 2, 2010 | 10:12 AM
Craftsman 18mm thin wall deep scocket
Old Feb 4, 2010 | 12:49 AM
996HAWK's Avatar
Backfiring
Got my other plug changed now its a whole different animal as far as power! But now i have a backfire if i rev the engine.Plug wires maybe.It doesnt miss or anything .Help hope its not jumping time.What headache did i get into.My wife loves the bike though maybe i,ll go with something else?!
Attached Thumbnails 1998 Superhawk wont start-007.jpg   1998 Superhawk wont start-008.jpg
Old Feb 4, 2010 | 09:43 AM
Mr Toad's Avatar
Deus vult!
Mr Toad is on a distinguished road
If it backfires when backing off/closing the throttle that's usually a result of a lean mixture. If it backfires under acceleration then that's a whole different ballgame - timing, intermittent spark, poor fuel delivery.
Old Feb 16, 2010 | 05:38 AM
quinnkelli's Avatar
quinnkelli is on a distinguished road
take off the peckcock take it apart and see if there is a hole in the diapham it might not be pumping enough fuel
Mr.Lojo
Feb 7, 2015 02:48 PM
herringcs
Dec 2, 2013 03:45 AM
tmoyer690
Apr 3, 2013 01:02 AM
hollywood13185
Apr 20, 2009 09:16 PM
ali_squidz
Apr 7, 2007 05:57 PM
