Satellite Radio
Old May 12, 2009 | 01:50 PM
DocPigskin17's Avatar
DocPigskin17 is on a distinguished road
Satellite Radio
I was wondering if anyone has hooked up a satellite radio reciever to their ride. If so, how? (ie bracket, wiring, wireless headphones, ect...).
Thanks in advance
Ride on...
Old May 12, 2009 | 02:01 PM
steve.g's Avatar
Check out these guys, www.tss-radio.com They are very good and have motorcycle specific kits.
Old May 12, 2009 | 02:38 PM
dakmatik's Avatar
dakmatik is on a distinguished road
Save your money and just hook a car kit up on the bike. I have XM on mine. I just bought the radio with the car kit, and stuck the base onto the triple.
You will need to wire in a power outlet to the battery. I say the battery, because I tried wiring it into the lighting circuit and I got a tone of alternator wine. After you're wired up, just run the cables to wherever you decide to mount it. I set the antenna on top of my brake fluid reservoir, and have no troubles with it there. All in all you will end up with a little bit of extra wire to hide, mainly the antenna wire, but it's an easy installation.
Most carkits have a line out jack that you can either hook into a communicator, or plug a pair of headphones into.
Here's a picutre of mine all set up along with my gps.
Old May 12, 2009 | 05:42 PM
RickB's Avatar
Wow, you have everything on there
Old May 12, 2009 | 06:37 PM
No doubt, you are all set up to put on some miles in style. How did you mount the car kit to the triple? Zip ties? Hard to tell from the pics. Also, double sided tape to mount the antenna to the brake resevoir?
Old May 13, 2009 | 02:59 AM
dakmatik's Avatar
I mounted the car kit to the triples with double sided sticky tape. For the antenna I used the double sided tape again and put a small, thin piece of galvanized steel cut to fit, so the antenna is held on by the magnet.
I'll take some more pictures tonight after work of the base and post them up.
Old Jun 29, 2009 | 06:09 PM
5150's Avatar
I don't need any Meds
5150 is on a distinguished road
so where are the new pictures coming in? i been waiting to see this mount for a while now.
Old Jun 29, 2009 | 07:11 PM
dakmatik's Avatar
Oops! I forgot all about it. I got busy preparing for my trip down to NC I totally spaced it off. Now that that's all done with I'll get them done ASAP.
Old Jun 29, 2009 | 08:44 PM
5150's Avatar
awesome thank you. i have been eagerly awaiting seeing all your mounting tips and tricks up close. i am curios too about something. what do you do when it rains? just not use these items or have you found a way to make it all still work?
I was thinking about doing some kind of clear lexan box with you know a waterproof seal around the opening. any thoughts on these kinds of things?
5150's Avatar
one more question. do you use jacked in earphones? or some other method to hear your tunes?
Old Jul 12, 2009 | 10:56 AM
Chilly996's Avatar
Chilly996 is on a distinguished road
I'd love to see those pics as well!!!!!!
Rollin20z
Nov 23, 2009 07:19 AM
Lifttruck
Jan 22, 2009 05:41 PM
Lifttruck
Jan 22, 2009 11:05 AM
Norcalblake
Sep 26, 2008 06:58 AM
DBLJ
Mar 5, 2008 06:24 PM
