APE Tensioner Installation...WTF!
Old Apr 24, 2010 | 05:44 AM
peterpanic's Avatar
pragmatic anarchist
Install APE tensioner in three easy steps.
1) obtain large quantity methamphetamine from overstock.com thanks Gary!
2) carefully place in a hollowed out banana at TDC. you can zip tie the banana shut but it doesn't matter.
3) place banana in monkey cage rotating 450 degrees anti counterclockwiseish, making sure the marks are the right way and the lobes are the other way and nothing slips off or jumps.
no need to remove battery ground cable. no more worries. loosen if too tight, tighten if too loose. do this install, you CANNOT afford the automatic tensioners, the monkeys just love that stuff!
I'm aware I'm an *** and I know this thread is useless without pictures!
Old Apr 24, 2010 | 07:12 AM
hondavtr1000sp2's Avatar
Old Apr 24, 2010 | 07:25 AM
nath981's Avatar
i would bring that meth to a slow boil and remove the toxins first. Last time I got it there, I was surprised and dismayed to find mercury in it. Rot Roe!
Old Apr 24, 2010 | 08:09 AM
peterpanic's Avatar
pragmatic anarchist
gee, thanks for adding ANOTHER step to what some of us consider an already overwhelmingly complex task (depending on the meds). Wasn't mercury supposed to go out of business like pontiac? oh, and i can't imagine Gary ever letting that happen! I won't type the word boil either, ****, got me!
Old Apr 24, 2010 | 08:19 AM
peterpanic's Avatar
pragmatic anarchist
So, do we love our apes?
Attached Thumbnails APE Tensioner Installation...WTF!-charltonhestonplanetoftheapes_new.jpg   APE Tensioner Installation...WTF!-monkey-gun-thumb-400x272-12159.jpg
Old Apr 24, 2010 | 09:22 AM
dshakes's Avatar
dshakes is on a distinguished road
o;sdfhwmqvoitw8nropweombp,jg0vc[er.[-cwfk.............................................. .............................?
Old Apr 24, 2010 | 11:16 AM
nath981's Avatar
without saying too much, a dealer sometimes heats the meth so he can cut it with something, for instance procaine, in order that he can recoup his money plus a little profit for his efforts. During this procedure when I happened to be there, mercury congealed into little droplets similar to those we used to play with and clean silver coins with back in grade school(in the 50's, before mercury got its bad wrap). This brings back another "toxic" memory, that we used to go into downtown shoe stores after school and x-ray our feet. hahaha. Yeah. you could stand up on this raised machine, stick both feet, your hands, or anything else you can get into the hole. Then turn the switch and you can see your hand or feet bones, move them around and see how they work for as long as you like or until the manager told you to get off.
As far as the CCT installation, it helps if someone else can be there helping you. i did the cheap CCT fix that some say isn't really a fix, but so far, so good. But doing your CCT is just like anything else, "you eat the elephant one bite at a time". You may find it easier to remove obstructions like the oil cooler or even the front wheel and forks to gain unfettered access, but you have to approach these tasks with patience, perseverance and look at it like a learning experience, and not a negative task. For example, steve and I probably worked at least 16-20 hours on his bike just trying to get it right, whereas others would have had it done in a few hours; but now we can tear the carbs off and put them back on again in a heartbeat. Look at like practicing and getting familiar with your bike. If I were closer or coming soon, I'd gladly assist you. There's gotta be someone close to you, but whether they would be willing to spend the time is another story.
Old Apr 24, 2010 | 01:20 PM
comedo's Avatar
I remember playing with mercury and the shoe store X-ray machines! Good times.
+1 on the importance of "patience, perseverance and [looking] at it like a learning experience". I've had to remind myself of that more than a few times.
Old Apr 24, 2010 | 03:00 PM
RK1's Avatar
RK1
For the tyrants who want to take away our apes, monkeys and bananas...
http://www.youtube.com/watch?v=O0B_UZNtEk4
Actually, if you follow the instructions on installing CCTs, it's pretty foolproof simple.
Old Apr 24, 2010 | 04:19 PM
peterpanic's Avatar
pragmatic anarchist
"get your hands off of me you filthy human"
Old Apr 24, 2010 | 04:21 PM
peterpanic's Avatar
pragmatic anarchist
but if you don't follow the instructions....
Old Apr 24, 2010 | 05:29 PM
In the '50s I remember kids bringing mercury to school for show and tell. And we'd all touch it. They'd have a kid arrested for doing that today.
My mom wouldn't let me play with the shoe store X-ray machine. I think she knew something.
Old Apr 24, 2010 | 06:12 PM
nath981's Avatar
Hahaha....... now we're giving away our age huh. Don't want anyone to know I'm 67. Shhhhhh. They're liable to start their ageism **** on us. hahaha
Old Apr 24, 2010 | 06:16 PM
nath981's Avatar
APE Tensioner Installation...WTF! that's Will Take Forever! if you keep procrastinating. Jump in there and "git er done". hahaha
Old Apr 25, 2010 | 06:00 AM
peterpanic's Avatar
pragmatic anarchist
Thanks for all the encouragement and amusement. I actually did mine a week or so ago and all went well. TPS and depair at same time. A few hours total. Had them too tight at first. Made a strange low growly squeal (no comments please). The real bitch was adjusting the front one with the coolant hoses in the way. I would say LAZNs walk through is basically exactly what I did, except I pulled the OEMs without releasing tension first, just made sure they broke free from the gasket and backed the mount bolts out slowly and evenly. They were in perfect shape ('02s). Ironically my post was a humorous break for all the guys that have been dreading the job. As all have said, take your time, read all the different posts several times, save most of the beer for after the test ride, and be sure to turn the motor by wrench several times before startup to be sure there's no "cash register from Hell" noises. Now go ahead and do it. The only problem I've had since the install is that Honey has quit a couple times while idling on the stand. Don't do that much so it may not be a new problem, but don't recall it happening before at all. If it grows into a concern I'll start a new thread...probably Monkeys killed my Bird.
Dad played in broken open bags of asbestos with his toy trucks and then payed 8 grand for abatement to sell a house 60 years later. Guy couldn't figure out his big grin as he spoke of the horrible dangers! My daughter bought a house a month ago and as we were leaving the walk through i spotted a small jar in the corner of the porch. Only item in the whole house, about a cup of mercury. When NATH visits we're gonna mix it with Jack Daniels. You get in trouble for tossing it in the reservoir! Good info on the meth, don't be insulted if I check it with the Amish up where my son lives!
You want me to procrastinate NOW? Maybe tomorrow.
Old Apr 25, 2010 | 06:57 AM
nath981's Avatar
My damn age is affecting my eyes. I know it! First it was difficulty seeing at night, black on black, etc. Now it's double vision. Sucks gettin old. hahaha................ Oh wait. Post 15 and 16. It's not double vision at all. It's freakin Alzheimers. Damn
Old Apr 25, 2010 | 07:18 AM
peterpanic's Avatar
pragmatic anarchist
what are you talking about?
yeah one more thing about the meth. don't post on it. twitchy ******' mouse button finger. seems alive!
Old Apr 25, 2010 | 09:20 AM
pigwings's Avatar
pigwings
Talking alzheimers
know how that goes, youngster
Old Apr 25, 2010 | 12:24 PM
nath981's Avatar
it's getting better. Now I'm hallucinating! hahaha
YTKinWI
Oct 19, 2010 06:24 AM
viperkillertt
May 7, 2007 08:26 AM
khanawalt
Apr 16, 2007 06:57 PM
L8RGYZ
Sep 26, 2006 07:13 AM
Racer647
Aug 21, 2006 10:22 PM
