VFR Bars/ Hawk Fairing interface
Old Oct 9, 2009 | 05:48 PM
BluStreak's Avatar
Question VFR Bars/ Hawk Fairing interface
Wonder if any of you guys w/ VFR bars can help me with this problem. I changed out the clip ons for these right after I bought the bike to help w/ the ergos. Have always had an issue with the dim/ bright switch contacting the bottom of the fairing. Recently, added the mirror extenders off of e-bay, to improve rear vision. After adding them, they exaggerated the conflicts with the fairing and bars, at one point to the extent of occasionally hitting the kill switch while turning left. NOT GOOD! I managed to use some rubber spacers between the fairing mounts and fairing to get it up off of that switch, but still have bright/dim switch conflicts and some further contact on more extreme turn angles. Next plan is to do some grinding on the mirror extender bases to make them better match the fairing contours. Then I'll see how much more shimming I can get away with. The ultimate limitation is the length of the threaded mirror mounts, as the shimming process leaves less and less bite for the nuts that secure them.
I don't want to have to cut the fairing. Any other suggestions?
Old Oct 9, 2009 | 05:54 PM
Moto Man's Avatar
Duc Hawk
Yeah I have been using urethane spacers similar to you but still get some contact on the Hi/Lo switch as well. I have thought about using thread extenders to allow a bigger spacers, but I think I'm just going to cut the fairing.
andy9743
Dec 26, 2009 07:40 AM
captkirk
Dec 21, 2009 04:07 PM
BluStreak
Nov 21, 2009 06:16 PM
captkirk
Nov 17, 2009 05:48 AM
andy9743
Mar 17, 2009 01:33 PM
