Taking the plunge: swingarm brace
Well, I decided to go go forward with adding a 900RR swingarm brace to my VTR. I just picked up a swingarm on eBay and will be cutting the brace off, having it welded on and then getting the whole thing powdercoated black. I will also be replacing the left footpeg bracket (was bent when I bought the bike) and having both brackets done in black as well.
I am looking forward to trying the reinforced swingarm to see how it feels.
cheers
cheers
cheers
cheers
if you feel anything it should be during corner exits with a bit of throttle.
ordinary riding?
i doubt it.
I'm planning the same thing on mine got the blade arm just need to find another storm one now and start cutting. I was thinking of maybe putting the rear caliper under the arm to make it clear the brace. Check out this pic not a blade brace but an R1 brace but the caliper is underslung looks cool.
Not sure what caliper bracket he has used will try and find out.
For doing that underslung option yuo should be able to take the stock bracket and rotate it 180 degrees... it has an excentric hole at the wheel axle... Then just fab up the link holding it...
The R1-modded arm is nice (being a member and frequent visitor of the vtr1000.org site, it's a familiar site
I was wondering about getting another VTR arm and doing the work then just doing the swap but as my bike is laid up for winter anyhow, I'll just prop it up on a stand, remove the present arm and do the work directly on it (saving me the trouble of having to sell off the one that is on there now; I already have boxes full of spare parts I can't get rid of...)
anyways as far as heat treating when you weld the swingarm anywhere close to the weld become annealed hence the need for heat treatment to maximize the new brace you put on otherwise I would say its just for looks because the brace and the heat from welding will probably nearly cancel out each other. I guarantee that the stock swingarm was heat treated. I used to work at a aluminum bike frame building company and before we welded the tubes for the frame if you dropped one it would dent or crush easily. After heat treat to get the same dent go grab a hammer. Just my two cents I don't think it is a must for safety or anything.
even just aesthetically i think that would improve the looks so much. I always found the swingarms to be a big crummy as far as styling goes. The rest of the bike has such great lines but the boxed aluminum swimgarm never really did it for me. I'm sure from a handling standpoint it would make a great difference too. I'll keep watching this thread to see how it all turns out
I just bought a 900RR rear caliper bracket too
For those who have done the mod, does the "anchor" located on the inside right of the VTR swingarm need to be altered/relocated/replaced if using the RR bracket or does using the bracket take care of eliminating the interference between the caliper and brace? (note: I have done a search on this but am still unsure exactly what has to be done)
cheers
cheers
Use the "anchor" or bracket from the inside of the 900rr swingarm, and the 900rr caliper bracket will fit into that. Using the 900rr caliper bracket will move the caliper and give you plenty of clearance from the brace. It's really nice and looks like it should have come that way in the first place.
https://www.superhawkforum.com/forum...ad.php?t=15061
RC
I actually thought of doing that but wondered about the compatibility of the different alloys (for the welding). I wondered also about the cost of doing the fabrication (something to consider if you don't do your own welding); the money saved in buying the aluminum stock could quickly be eaten up with fabrication costs. In the end, I picked up a used 900RR swingarm for $20 on eBay, making the fabrication option a non-issue.
I've never chopped open a superhawk swingarm but I did see the inside of an rc51 swingarm and it already has yellow foam inside so good thinking.
