Steering head bearings
Old Jul 19, 2009 | 08:15 PM
autoteach's Avatar
So, my bike started making a "knock" when the brakes were applied. I assumed that the bearings got a little loose and needed a little adjustment. I tightened the steering head and now it has "autopilot". I have had some luck with tightening bearings up before, but word to the wise, if you do not have the spares sitting around, let it knock. Now its parked until Tuesday when the parts come in. Oh well, it was about time I did some maintenance to the bike.
Old Jul 19, 2009 | 11:52 PM
CentralCoaster's Avatar
I need to do this also. Its pretty obvious to me what the issue is after 34,000 miles but surprisingly the bike shop didn't have a clue what's causing it.
Old Jul 23, 2009 | 05:57 PM
shayne's Avatar
I found the bearing very hard to set by feel. I had a couple of goes at it and the bike wasn't right. My advice is to buy (or make lake I did) a special tool and put a torque wrench on it. I had no more problems after that.
Old Jul 23, 2009 | 07:34 PM
Replacing the neck bearings is crutial to proper handling. The more "tuned" you are the more critical the tolerances. When Greg did my forks I replaced the stockers with the conical bearings from allballz. What I was not prepared for was the settling of the bearings as they have aged. I have tore the triples off three times to retorque and only get a few thousandths per adjustment but it significantly changes the suspension when this play is removed.
You're right it is a knock over uneven pavement that gives you the clue.
Old Jul 23, 2009 | 08:03 PM
chickenstrip's Avatar
chickenstrip
Ya got pics of that tool? I've always had a hard time getting the torque on the steering bearings right.
Old Jul 23, 2009 | 11:01 PM
Circuit_Burner's Avatar
guru of things sparky
Its called a spanner wrench.
Old Jul 23, 2009 | 11:13 PM
That must confuse the English guys.
Old Jul 24, 2009 | 12:42 AM
Syclone's Avatar
Boosted
Honda part number is 07916-3710101. I'm tired of screwing around with a hammer and punch trying to set torque on it, so I ordered one from Service Honda.
Old Jul 24, 2009 | 05:38 AM
chickenstrip
Never seen one with torque wrench capabilities.
I've got one I picked up randomly years ago ... doesn't fit my bike. I'll check Harbor Freight .... spanner set - $54
Old Jul 24, 2009 | 06:34 AM
reaper's Avatar
Or save yourself some money and purchase a 3/4" drive 12 point 1 11/16 socket that will do the same thing. Make sure you torque only to 18 ft./lbs.
Old Jul 24, 2009 | 07:28 AM
steve.g's Avatar
Sometimes!!...
Wrench = Spanner
Spanner = Special tool for tightening the castle nut on the head race of the triple tree..
Old Jul 25, 2009 | 03:38 AM
shayne's Avatar
Sorry no pics.
I made it out of a socket so my torque wrench would fit on, and then welded bits on to to fit it to the special nut. Looks a bit rough but works well.
Old Jul 26, 2009 | 10:03 PM
Syclone's Avatar
Boosted
+1 to this. Service Honda emailed me back that those special Honda tools go straight to backorder, and I wanted my bike put back together, so I went down to Sears today and picked up a 3/4" drive 12 point 1 11/16 socket for $20 and an adapter down to 1/2" drive for $7. Worked perfectly.
Old Jul 27, 2009 | 08:56 PM
nath981's Avatar
I over-tightened mine and rode for several months until some head shake forced me to take it apart and redo the bearings. There was so much difference when I tightened it correctly that I had to take it apart again to see if it was too loose, but it was fine. Just tap firmly with large screwdriver/hammer until it stops, turn steering back and forth to make sure there is no resistance. Note where you're at and loosen again. Then re-tighten and you should end in the same position with the same result in terms of turning ease. that's my experience.
Old Nov 3, 2009 | 11:51 AM
chickenstrip
Picking up on this one ....
I'm a little confused about this tool description - are you talking about sockets for the stem nut on top of the triple clamp? I'm looking for tools, spanner wrenches, for the the two collar nuts (correct name?) that sit below the triple clamp.
Is there an alternative to buying a set of spanners for $35?
To anyone who's bought a set of spanners ... did you have any trouble with them fitting the nuts? Anything to look out for?
Thanks!
Galaxieman
May 29, 2012 11:58 AM
3D02
Jun 18, 2007 08:43 PM
Babelfish
May 17, 2007 04:48 AM
Rollingalong
Jul 24, 2006 03:44 PM
bkelsey
Jul 25, 2005 12:21 PM
