Tapered Steering Head Bearings
Old Dec 21, 2004 | 06:19 AM
Rollingalong's Avatar
Rollingalong
Just a heads up that allballsracingdotcom makes steering head bearings for our bikes .
If you local parts source can buy from Parts Unlimited the good deal on them might be about 25 bucks
part # 221020
They make front and rear replacement wheel bearings too for you hi-milers ............ I bought all 3 for my keeper cause I'll eventually need them .
Old Mar 11, 2005 | 03:45 PM
HotStreetVTR's Avatar
HotStreetVTR
Re: Tapered Steering Head Bearings
Marietta Motorsports (Mar-Mo) http://www.1888fastlap.com also carries the high-quality tapered head bearings, which are both less expensive and of better quality than OEM head bearings are.
cheers,
--HotStreetVTR
Old Mar 11, 2005 | 05:52 PM
102dals's Avatar
Is there a forum post to help with this install?
Old Mar 15, 2005 | 05:49 AM
Rollingalong
I have not seen one but you knock them out with a punch and hammer .
Lube the OD and drive them in with either the old bearing race or a socket .
Old Jul 22, 2006 | 11:46 PM
SillyHawk's Avatar
SillyHawk is an unknown quantity at this point
how can you tell if you need new bearings...is there a certain mileage you hit and the bearing need replacing?
Old Jul 23, 2006 | 02:24 AM
shayne's Avatar
Get the front wheel off the ground, and check side to side movement. If it is not nice and smooth bearings may be past their use-by date.
Old Jul 24, 2006 | 12:06 PM
ff's Avatar
ff
ff is an unknown quantity at this point
what is everyone using in there front end conversions??? same bearings (oem size) with the 954 triple and stem???
Old Jul 24, 2006 | 03:44 PM
JesseW.'s Avatar
JesseW.
they make custom bearings so you can get them with the outer diameter for the superhawk and an inner diameter that fits the steering stem of another bike.
Galaxieman
May 29, 2012 11:58 AM
bkelsey
Mar 13, 2008 08:31 AM
ff
Mar 9, 2006 05:12 PM
superhawk22
Nov 14, 2005 06:40 PM
bkelsey
Jul 25, 2005 12:21 PM
