Single exhaust...LOUD
Old Jun 15, 2007 | 06:18 PM
Josh's Avatar
Minimal Post
Josh is an unknown quantity at this point
So I've put on this used single exhaust that I bought on ebay. The slip can is unknown. It has got any kind of marking whatsoever. The good thing is that I can really tell the weight difference. Also that the bike seems to be running as it should with no lags or popping or anything. Could be just mental, but it seems like it has a little more pep in the middle. The bad, maybe, is that it is loud! Not so much at idle, but between 1000 and 3000 rpm on the throttle, the sound pulses are pretty rockin. After that, it is pretty smooth at higher speeds. Maybe because I've only had the stock pipes with 4 hole bafflectomies per, that it seems a whole lot louder.
So I'm assuming that I should try to repack this unknown can at some point if I want to get it quieter. Or should I just try and put a different can on? Also, anyone have any idea what make this can could be? Need to come up with a better exhaust clamp, strap, bracket. My sucks. Comments....please.
Old Jun 15, 2007 | 06:28 PM
trinity012's Avatar
Hi Josh, I believe that is Muzzy Kawi. Deep tone sound.
Old Jun 15, 2007 | 09:55 PM
Josh does it have double side by side springs, or at least the mounts anyway, on the inside(swingarm side) of the midpipe and the can? Actually looks like a round Hindle with a homemade clamp. I just sold a pair of these recently and it's identical to the pics I have. Had a round Muzzy (which is VERY similar) on my ZX12 and it has a short inlet pipe as part of the inlet cap like most do, whereas the one in your pic/Hindles have an inlet cap with just a hole and the midpipe slips into the actual can. V&H ss2r's are like this too. Hope this helps.
Old Jun 15, 2007 | 10:22 PM
Josh's Avatar
Minimal Post
Yes, it has a double side by side springs. The mid pipe does slip into the can as well. Thanks for the help Trin and Cap.
And yes, it really is that green here.
Old Jun 21, 2007 | 05:12 PM
joshn569's Avatar
joshn569 is on a distinguished road
that thing must sound nasty
SuperHawkins
Apr 10, 2014 03:38 PM
adam75dfw
Jun 16, 2008 06:35 PM
SlowHAWK
Oct 28, 2007 08:33 PM
nova_scotian_996
Jan 1, 2007 03:37 PM
Dustin420
Jul 5, 2006 02:37 PM
