Replacing sprockets any special tools or or advice needed?
I ordered a 15 front and 43 rear sprocket set and a speedo healer. Do I need any special tools or will a basic metric wrench and socket set do? From reading other posts my stock chain should work but will i have to take the master link out to get the chain off and back on? The service manual says the masterlinks are staked but ive never used that type only the clip kind.
Anyone that has done it got any tips for me to make it go more smoothly?
why is it that I can rebuild a small block chevy practicaly with my eyes closed but I am leery of changing sprockets on my jap bike lol
If you're removing the sprockets, then you won't need to break the chain, just put it on the new sprockets and bolt them on, very easy. Popular wisdom, however, is that you should change your chain and sprockets as a set, because they both wear out and wear on each other, so a worn chain can cause your new sprockets to wear out more quickly.
Most modern bikes (all?) don't use clips any more. You have to grind off a link, and then use a chain link tool (or a hammer and punch) to stake a new link and pin on the chain. But that's only if you must break the chain.
Hope this helps,
Mike
Also, just in case, be sure that your chain (520, 530, whatever) and your new sprockets are the same size.
Hope this helps,
Mike
Hope this helps,
Mike
Hope this helps,
Mike
On a VTR you can remove and install an endless loop chain, no problems. All you need to do is remove the nut on the swingarm bolt, remove the left rear set and it comes right off. One of the advantages of having the swingarm bolt to the motor and not the frame.
thanks for the replies. I feel a little more confident putting them on now. The sprockets came in today and speedohealer should be here tomorrow. If im not entirely drained from work ill try to install it all. cant wait to feel the difference in the bike.
Well based on my personal experience; Unless your chain has at least 12k or 15k miles on it and you haven't taken very good care of it?
Yeah, it's all in your head.
Let us know what difference it made. I've been toying with this idea for a while now as I don't find the hawk has a ton of hold on for dear life get up and go power.
CentralCoaster
May 16, 2009 05:51 AM
