Rear Shim Advice
Old May 7, 2007 | 10:17 AM
NovaWildcat08's Avatar
NovaWildcat08
Rear Shim Advice
For those of you who have risen the rear ride height by adding a shim on the shock mount, did you all machine the shim yourself (I have the CAD of Greg's shim), or has anyone found washers thick enough to do the job? I'm probably lookin to go with the standard 5mm for starters and then adjust from there. Thanks for the help.
Old May 7, 2007 | 10:20 AM
killer5280's Avatar
I use a stack of fender washers I bought at the local hardware store for pennies. I even cut a notch in them so I don't have to completely remove the shock to make adjustments.
Old May 7, 2007 | 12:17 PM
RPV-Hawk's Avatar
RPV-Hawk is on a distinguished road
I use a 1.25" washer cut with a hacksaw/dremel into a "U" shape to allow me to slip it in without removing the entire shock bolt. Works great. Just loosen the shock nut, and lift the bike to allow the rear suspension to 'droop'. You can then just slide it in. Use 2-5 of em to get the ride height adjustment you're looking for.
Old May 7, 2007 | 02:22 PM
Zedicus's Avatar
Zedicus is on a distinguished road
i just used a stack of stainless washers that fit the bolt snuggly and angle grinded a notch so they would slip on... its more adjustable that way.
Old May 7, 2007 | 02:46 PM
The Hawk Guy's Avatar
The Hawk Guy
Smile
Just a quick question on this topic, will this (rising rear height) make the shifting easier or no effect? And what's the main reason many people are doing this? Thanks a lot!!
Old May 7, 2007 | 03:05 PM
killer5280's Avatar
It only affects ride height in the rear, which makes the bike steer quicker. Shimming the rear has no effect on shifting.
Old May 7, 2007 | 03:14 PM
jamesvtr's Avatar
jamesvtr is on a distinguished road
i used a chevy front end alignment shim
Old May 7, 2007 | 03:43 PM
NovaWildcat08
Thanks a lot everyone. After exams are over and I have some free time I'll be playing around with it.
Old May 7, 2007 | 05:48 PM
SlowHAWK's Avatar
I'd suggest using/testing with multiple shim heights before bolting everything back in place... I put 6mm in right from the start, put everything back together and then realized I couldn't put my feet flat on the ground afterwards!!! In the end, 4mm worked nice for me.... good reason to use a few washers instead of having someone machine a plate for you. A small change at the shock makes a noticable difference elsewhere!!!
J.
Old May 8, 2007 | 10:37 AM
autoteach's Avatar
Relating to the present shim question, what setting do most of you have the rear spring adjuster at. Should I crank it for max preload? I dont know what to do, except that with my new undertail, I dont want to run the risk of tire/exhaust impact.
Old May 8, 2007 | 11:22 AM
I tried to get a 6mm shim in and it wouldn't go as the suspension linkage was contacting the pipe (not sure how some of you got yours in there) so I settled on one that is 4.7 mm thick (or 3/16" if I recall correctly).
Old May 8, 2007 | 11:26 AM
RPV-Hawk's Avatar
There should be no way the rear tire should/could contact the undertail unless you remove the shock or one of the links. There simply isn't that much travel in the rear suspension, unless your undertail is REALLY low.....
Way back when I still had the stock rear shock, even with 250 lbs of rider and a 150lb passenger...I still never bottomed the rear.
By raising the rear ride height, you put more weight on the front end. Makes it harder to wheelie(more weight on front end), gives better front end feel, and also makes turn in faster.
I run 4mm on the street and 7mm for track days.
I'm running different headers (2-bros) so I don't have the linkage/pipe interferance problem.
Old May 8, 2007 | 05:45 PM
autoteach,
Set up your rear preload to achieve 25-30mm of rear sag. Front should be set up for 30-35mm of sag. Setting sag is always the FIRST step in adjusting suspension.
There is an article in the Knowledge Base section on how to set sag.
Old May 8, 2007 | 06:06 PM
autoteach's Avatar
Crap of it is, I am still waiting for my headers, and I am just finishing up the wiring. I guess if I finish thursday with wiring, I can set my sag, prob. on the lower side, and see where that puts me with the undertail exhaust. I will have to carry my spanner wrench with me for the chicks.
"How much do you weigh?" Probably won't go over well with the chicks, I imagine I will get the "well, HE doesn't have to adjust HIS suspension before I get on." Maybe followed by my reply of, "Get a ride from him, then. oh yeah, you looked too fat for my bike."
Old May 8, 2007 | 06:10 PM
One or two stickers on your tail section will cure the problem:
"NO FAT CHICKS"
and
"WEIGHT LIMIT: 130 lbs."
Old May 8, 2007 | 08:04 PM
"One or two stickers on your tail section will cure the problem:
"NO FAT CHICKS"
and
"WEIGHT LIMIT: 130 lbs." "
he he, I love it
Old May 8, 2007 | 10:22 PM
Chitownson's Avatar
Chitownson is on a distinguished road
I did the rear shim thing using some large washers from Lowes I cut with a dremel - it worked great, really helping the steering. I've seen other people describe this as more flickable. Really helped reduce runout in turns.
Unfortunately, when I did some work on the forks and put them back on the hawk, I dropped the forks about 5 MM in the in the mounts and this really made the bike handle but when I ride on straight bumpy roads, the bike feels really skittish. I have to work on the bike for something else this weekend so I am going to try I changing the forks to only about 2 MM drop in the in the mounts and seeing it this creates a nice compromise.
Old May 9, 2007 | 05:58 AM
Is your sag set correctly?
Old May 9, 2007 | 11:54 AM
YellowHawk's Avatar
YellowHawk is on a distinguished road
I made mine from aircraft aluminum (nice and light), a solid piece cut to shape and nothced per Greg's sight. Mine is about 7/16 inch thick. I am 6' and 1" tall, so the added height was wlecomed to me, plus it seemed a lot more flickable entering the corners. I ride with full rebound and dampening in front and back.
Old Jun 8, 2007 | 11:01 PM
vtrider's Avatar
roll through
vtrider is on a distinguished road
how big of a hole needs to be in the shim or washer?
Old Jun 17, 2007 | 07:19 PM
10mm
Unzie57
Feb 3, 2013 05:58 PM
gboezio
Sep 23, 2008 08:45 PM
DDohio
Apr 24, 2006 09:27 AM
CNI Dawg
Nov 13, 2005 05:47 PM
ClevelandSuperhawkRumble
Mar 25, 2005 01:27 PM
