Quietest exhaust
Quietest exhaust
Before someone points out that a newb is asking an exhaust question (which happens all the time), I'd like to make it known that I did run a search and wasn't happy with the results. So here's the question: what is the quietest aftermarket exhaust I can get for the VTR? I primarily want to increase power while reducing weight of the stock system, but I will gladly keep the stock system if everything out there is going to be significantly louder. Truthfully, I want something that is as quiet as stock, but I'm sure that's almost impossible.
There is nothing as quiet as stock that will flow any better, in fact there are a few systems out there that don't flow as well as stock and are louder. If noise is truly a concern stick with stock!
I had carbon fiber Yosh slip ons. Nice sound and not too loud. Just replaced them with Jardine high-mounts.....quite a bit more noise.
Also have the stock pipes, yeah they are the quietest, but do weigh a ton....
I have had the Yoshi RS-3 low mounts and Jardine Highmounts Race Baffle 2".... both are louder than stock... I thought the Yoshi's were a bit quieter at neighborhood speeds... but I'm sure having the 2" baffle instead of the 2.5" baffle makes a huge difference on keeping the noise down on the Jardines.
J.
J.
I've read a lot on this topic and have come to the conclusion that the Yoshi pipes are the least loud of the aftermarket pipes... But you wont get stock sound levels unless you run stock.
Any aftermarket should reduce the weight. Just check their specs for how much. I can tell you that the difference between my stock pipes and the 2Bro's pipes was significant!
I loved the Yoshis... very well made... very good product. They were Stainless Steel... so a bit heavy compared to the Jardines I have now which are aluminum... but the Yoshis had a better quality fit and finish.
J.
J.
Too funny, I to "traded up" from a 919, both super fun bikes, but I am having a much better time on the superhawk as of late.
Yeah, I think weight and sound will the real advantages on the superhawk. As mentioned I had the stock, Yosh carbon and Jardine's. As far as sound I really do like the Yosh pipes the best.
Although it is kinda fun to scare the neighbors with the Jardines
I may be inclined to sell the Yosh pipes, just don't want to deal with boxing and shipping. I'm in So Cal.
Sorry to hi-jack, but.... If one was to put stock pipes on a bike that has been jetted for aftermarket pipes, what would the effect be? With noise restrictions at some of the most desirable tracks, I would like to be prepared to put some stock cans on every now and then to be legal at those trackdays. Do I need to rejet, or will I just lose a little performance. Might it be running a little rich?
Or, is there a way to quiet down aftermarket pipes?
Hey I'm big fan of "quiet but not as quiet as stock" exhausts too. Cheapest: a "lite" bafflectomy. Next best bet would be a Euro-spec street legal exhaust. These typically come with "spuds" aka sound deadeners to pass but can be removed. I have a set of Leo Vince Evo II's (street legal line) on my VFR and the sound level was about perfect for me.
Kind of an apples to oranges comparo but here's a sound clip on my VTEC VFR that has a catcon. I was really happy with the dB levels:
http://www.youtube.com/watch?v=8ldjrL7kbm8
And here's the same set but now mounted on a different model vfr without the catcon. It's just a tad too loud for me but certainly still on the low end of the loud scale:
http://www.youtube.com/watch?v=18JIXXJYpWM
The spuds are in both videos but the second one is louder due to less restriction.
It's refreshing to hear somebody ask for quiet pipes.
I'm using RC 51 mufflers which weigh 1.5 lbs less than stock per side. and look and sound better than the stock ones.
The way I mounted mine I had to give up passenger pegs since they are midway between the stock height and what they are on the RC51.
Kai Ju
Kai Ju
Sorry...
kai ju... Since I like the sound in my stock pipes with a full bafflectomy, and feels the only benefit with slip-ons would be the weight, more noise being neither win, nor loss... I might be interested in going your route... More bass, same volume?!
What would I need to do to make a pair of RC 51 muffler fit? and would you say it's possible to keep the rear pegs?
Kai Ju
Kai Ju
I have 2bros on now but have the stock vtr bafflectomied cans and a full rc51system...
Kai Ju
Kai Ju
Passenger pegs
Tweety...yes you can keep the passenger pegs. Do a search and you will find more details. Basically you need longer bolts that go into the subframe and some sort of spacer that is long enough for the passenger peg brackets to clear the pipes. I got everything at a hardware store (Fastenal) for about $10 so I could keep them on my high mount 2 Bros.
1. There are probably ways to keep the passenger pegs, as Hotbrakes mentioned, I just didn't sped any time researching since I always ride solo, and like the high pipe look.
2. The vents in the cowl were made by me. They help with airflow for the underseat radiator installation. I laid out the shape, cut it out with a cut off wheel and finished it with a woodrasp and sandpaper. The aluminum mesh is bonded to the inside of the cowl.
The footpegs are CBR600 F4 and are bolt on's.
3. The RC51 pipes were installed to the stock headpipes by taking the stock mufflers and cutting off the midpipe just below the muffler. Then you cut the midpipe off the RC51 muffler but leave it long, as shown in the pics.
Have a muffler shop expand the stock midpipe that you just cut off to where it just fits inside the RC51 midpipe. ( Pick a good shop, my first choice ruined my first set of midpipes )
Slot the RC51 midpipe on the bottom where you're going to install the bandclamp and fab up muffler hangers.
You maybe able to combine the parts for the two pipes in a way that brings the RC51 muffler at the stock height which should allow you to keep the stock hangers.
Kai Ju
Kai Ju
Kai Ju
Kai Ju
Seems to me that the simple solution would be to leave the RC51 mid long and weld the orginal mid to it at a slight angle (clamp free) since I have the tools to weld it myself...
I got Leo Vince Evo II slip-ons about a month ago. At the end of the muffler is an insert which is retained by a tamper-proof screw and there is an additional baffle, a perforated disc, which fits between the midpipe and the muffler. The system is quiet to a fault. It's barely louder than stock. I haven't dyno'd it yet.
SlowHAWK
Oct 28, 2007 08:33 PM
