Question about Jet Kit
Old Jun 10, 2009 | 05:42 PM
johnclopp85's Avatar
johnclopp85 is on a distinguished road
Hi, I recently installed a K&N filter on my bike. I already have a set of d&d pipes on it. The bike now seems to be "chuggy" or "bucky" around 3200-3500 rpms. I figure putting a jet kit on it will solve this problem. However, I was wondering does jet kit significantly reduce your mpg? Any other input on jet kits would be apprieciated THANKS A BUNCH.
Old Jun 10, 2009 | 05:45 PM
drew_c14's Avatar
If your bike has stock jetting and you now have a K&N then you will have to re-jet to get it right again, no doubt about it it. There is a bunch of information, and really smart people here when it comes time to install it.
Old Jun 10, 2009 | 07:28 PM
comedo's Avatar
+1 on what drew 14 said. You might want to try shimming the needles first. If that's not satisfactory, go for a jet kit. My guess is that, in normal street riding, you'd probably have worse mileage by keeping the bike revving above the range you find annoying than by having the bike jetted properly and making that rev range useable.
Old Jun 10, 2009 | 08:55 PM
nath981's Avatar
before I would re-jet, I would set your air mixture to 2 1/4 turns out, shim the needles to .40, and set your TPS at 450-500ohms. I modded my airbox and put a foam oiled filter with de-restricted exhausts along with the aforementioned mods and it runs perfectly.
Philipian Ricer
Jun 24, 2023 04:52 AM
Cleveland
Mar 27, 2007 07:01 PM
Scumbag
Mar 15, 2007 03:25 PM
EngineNoO9
Jun 17, 2006 09:59 PM
Shmittay
Jan 19, 2005 05:33 PM
