Picking up 98 900rr front end this weekend
Old Oct 27, 2006 | 10:13 AM
Letsrideinsc's Avatar
Letsrideinsc
Howdy,
I"ve got the bike on stands starting the mcct swap, and an ignition advancer for fun. while it's out of commission I decided to do the fork swap too!
So I found a full 98 900rr front end w/wheel, rotors without clipons locally here in Santa Cruz. I've scoured this site and others about the compatibility of the 98 forks vs the 93-95 900rr forks. these 98 forks don't have the extended stanction tubes, but I figured I'd set up the triple tree so the top of the legs are flush with the top and install some 45mm heli bars. Does this geometry sound correct?
Also, is there a way to determine by looking or measuring the 900rr forks so I can make sure these are for sure 98's, the seller is almost 100% positive but isn't sure. Thanks for any input.
Input greatly appreciated!
-Jeromy
Old Oct 27, 2006 | 01:57 PM
JamieDaugherty's Avatar
Be really careful, the 900RR forks are pretty short. You should make sure to check all clearances. I normally do this by taking the fork caps off and removing the springs. This will allow the forks to completely bottom. You can then check your settings to see that the wheel doesn't hit anything.
Old Oct 27, 2006 | 02:45 PM
selztoad's Avatar
hope you didnt get the 16inch front wheel yuck
Old Oct 27, 2006 | 05:36 PM
superhawk22's Avatar
If you did get the 16" wheel get yourself a cbr f3 wheel, a 900rr rear wheel is direct swap as well.
Old Oct 27, 2006 | 05:55 PM
selztoad's Avatar
So you can buy a 900rr rear wheel and it bolts up no problem?
Old Oct 27, 2006 | 05:58 PM
I've got one on my bike right now.
Old Oct 27, 2006 | 06:05 PM
As a matter of fact, marmaladeboy has one for sale, I was going to get as a spare but haven't had the money so...
https://www.superhawkforum.com/forum...ead.php?t=3662
Old Nov 8, 2006 | 11:30 AM
WPLFEMAN's Avatar
WPLFEMAN is on a distinguished road
99 Hawk
LOOKING FOR USED FRONT ROTORS 99 HAWK JEFF AT 920-729-9801 OR JWOLFESNEENAH@AOL.COM
Old Nov 8, 2006 | 02:15 PM
WPLFEMAN,
You have a PM from me, though it's not concerning the rotors.
Old Nov 8, 2006 | 08:29 PM
[QUOTE=superhawk22;33867]As a matter of fact, marmaladeboy has one for sale, I was going to get as a spare but haven't had the money so...
No he doesn't! It's on its way to me!
thedeatons
Aug 2, 2013 04:40 PM
skoshere
Jan 13, 2009 05:22 PM
CentralCoaster
Sep 15, 2008 10:05 AM
Erik S.
Nov 28, 2007 06:31 PM
Randman
Dec 1, 2005 09:38 PM
