new shock
Old Nov 8, 2014 | 10:50 AM
twist's Avatar
new shock
I recently bought a FOX clicker shock from captainchaos, great seller and all around super dude. I'm amazed at the difference it makes on the bike, it's like a different bike. Now I'm dialing it in and I notice how much the front end needs adjustment, too. I have Jamie's springs in front but the old settings don't feel right after the FOX shock. I can adjust the rider height so now the VTR turns in faster. It's like the difference between riding a hardtail frame and a modern sprung rear end. Thank you captain!!
Old Nov 8, 2014 | 05:39 PM
Killemall's Avatar
Interesting. Did you end up with too much sag on the fork after mounting the new shock? I'm planning to run the same setup. I already have the JDM front and I just bought a Fox TC. I'll probably send it to Jamie for a proper setup but I'm curious to hear what settings you'll settle with.
Old Nov 9, 2014 | 11:34 AM
I also have installed a Fox TC. The change is astounding. There is a couple of threads about the best performance mod, and IMO a shock upgrade is it.
I was lucky that the shock had the right rate spring for my weight so when I sent it off the Jamie I didn't have to re-spring and valve it, just fresh seals and N charge.
I am at 11 clicks out on the rebound and compression is at 3. I have no index mark for the compression so take that for what it is. I think that I need a little more rebound damping have adjusted to 9 out, but have not tried it out yet.
If you don't already have this:
Fox Manual.pdf
Old Nov 10, 2014 | 07:17 AM
JamieDaugherty's Avatar
If you only did springs then it's your problem - you really need to address the valving in the VTR forks. Springs alone are not a solution, and in some ways are actually a step backwards. I think what you are probably feeling is the ill-effects of the stock valving.
Keep chassis adjustments to a minimum. Do not lower the front and only raise the rear a couple of mm. Any more and you might think it feels better but your actual handling performance will suffer.
Old Nov 10, 2014 | 09:47 AM
NZSpokes's Avatar
I dont think anybody mentioned forks?
Old Nov 10, 2014 | 10:34 AM
waltr's Avatar
Not Realy A Squid
waltr is on a distinguished road
twist
Killemall
Old Nov 10, 2014 | 10:58 AM
Correct, I thought the OP's question was concerning the performance of the front end.
Old Nov 10, 2014 | 05:03 PM
twist's Avatar
I think the shock needs to be adjusted for rebound damping as it wallows a tad in turns, especially the exit. The shock is set at 9 clicks out and compression damping is set at 5.
I'm sure I could use the re-valving in the front end but didn't have the cash at the time.
Old Nov 11, 2014 | 08:24 AM
Killemall's Avatar
Good info. Thanks for sharing. My Clicker is on its way to Jamie. My fork has JDM valves and springs. I can't wait to try this setup
If the rear seats higher with the Fox TC, wouldn't that shift the bike weight ratio slightly to the front and therefore require adjusting the sag on the fork?
Old Nov 11, 2014 | 09:34 AM
Adjusting the ride height does not actually change the weight bias any measurable amount. It does, however, affect the dynamic effects. For example, during corner entry or corner exit the suspension will behave slightly different when you change geometry. Sag is not affected.
Old Nov 11, 2014 | 09:37 AM
Something to keep in mind is this: more often than not a problem with the front will be reflected as a bad feeling in the rear (and vice versa). If you have stock valving in the forks don't expect the shock to perform to its best ability.
Old Nov 11, 2014 | 09:59 AM
CrankenFine's Avatar
Jamie - this is like the same conversation you and I were having after I installed the F4i shock. I also have a stock front end other than .90 Sonic springs so my subjective experience of a wallowing rear is the same as noted here. I followed your advice increasing preload and compression on the shock and noticed improvement. I still need to get the front forks valving addressed.
Old Nov 16, 2014 | 05:59 AM
nnjhawk02's Avatar
When I did my suspender change, I didn't **** around. I went to local experts.
New springs, valves to go along with the Ohlins, and then dialed in the settings to my weight, with me on the VTR. I've never looked back. Best mod evuh.
Old Nov 16, 2014 | 04:51 PM
twist's Avatar
there's a local shop here that does great work in that regard. I thought of Jamie but for the money it's easier and cheaper to do the work locally, I'm going to do what you did.
superbling
May 6, 2008 04:24 PM
superbling
Jun 16, 2007 07:08 AM
Rollingalong
May 22, 2007 01:28 PM
Shaunlaverty
May 8, 2007 08:40 AM
superhawk22
Sep 23, 2006 04:19 PM
