More tinkering...
Old Apr 4, 2015 | 11:02 AM
More tinkering...
Getting the bike ready for the season, so I got around to doing a few small things yesterday
- installed the LED voltage sensor; drilled out the hole where the "phony bolt" is on the stock cluster, and it looks OEM.... now I will know if my stator acts up....
- replaced the tip on my JDM shifter with a Woodcraft folding unit.....
to do:
- get tires installed on Dymag rims (bought protectors and special tire lube from Brock's) and install on bike (have spacers and new pads for calipers - larger CMC rotors; give the calipers a good cleaning too, as well as inspect the condition of the DLC-coated caliper pins...)
- install updated/modded carbs (will snap pics of my H-wing diffusers, if anyone cares to see....)
- remove shock and have it rebuilt (disassemble, clean, inspect, lube linkage); I plan on either reducing or eliminating the rear shock shim (presently at 5.3mm) to help give the bike a bit more stability...
Feel free to share your latest projects...
Old Apr 5, 2015 | 01:33 AM
NZSpokes's Avatar
I wanna see the H wing!
I have been told on a VTR with correct settings on the suspension the most shim you need is 4mm. Thats what mine has and its rock solid. Turns very well.
My current project has 4 paws and a tail. Not had a dog in 15 years so having some fun with my new mate.
Aug 27, 2014 03:14 PM
finepooch
Mar 29, 2009 04:58 PM
Chuey
Apr 1, 2007 07:38 AM
Zedicus
Mar 12, 2007 11:09 AM
Otto Man
Mar 10, 2007 07:40 PM
