Lowering Foot Pegs
Old Nov 25, 2018 | 01:52 PM
YMRacing's Avatar
Smile Lowering Foot Pegs
I've done a search, and all the stuff points towards a BMW footpeg, but...when I click on the links....all 404.
I need another inch....-Richard Pryor said that too.
Old Nov 25, 2018 | 06:37 PM
VTRDarren's Avatar
VTRDarren
I’ve noticed these for sale here and there. Might work for you.
https://www.ebay.com/itm/Shinobi-Bla...-/351086126830
Old Nov 26, 2018 | 03:20 PM
YMRacing's Avatar
Thanks, I'm looking into them. Asked if they might fit.
Old Nov 26, 2018 | 03:36 PM
Cadbury64's Avatar
VTR virgin
I've tried some pegs similar to those, no issues fitting them but I ran into a clearance issue with the gear shift lever. Granted I have big feet and seem to need my lever lower than others, but IIRC there was contact between the lever (where the rose-joint mounts) and the lowered peg mount when pushing the lever down.
Old Nov 29, 2018 | 04:24 PM
YMRacing's Avatar
15 EW boots...Not sure what you mean by IIRC...And, they have as yet answered my question.
Old Nov 29, 2018 | 06:12 PM
Floyd's Avatar
If
I
Remembrer
Correctly
Old Nov 29, 2018 | 06:22 PM
YMRacing's Avatar
I'm an old guy...thanks.
Old Dec 5, 2018 | 03:39 PM
OldGuy's Avatar
OldGuy is on a distinguished road
...all the stuff points towards a BMW footpeg....
I don't know about BMW pegs but Buell footpegs are a common way to lower rider footpegs; I have them on my '98 FireStorm and they are a Godsend for my bad knees.
Here's one thread regarding the Buell mod: https://www.superhawkforum.com/forum...-w-pics-18257/. There are other threads if you do a search.
Old Dec 6, 2018 | 01:45 PM
on the aforementioned link I think I posted up about my mfw vario adjustable footpegs see below link
I think a 1in and a one and a half inch adapter is available and a couple three different styles footpegs all the Hondas use the same pivot piece I believeMuch tricker components then adapted Buell foot pegs
I've been running the mfw units for at least Dozen Years and I'm no lightweight
https://www.revzilla.com/motorcycle/mfw-vario-rider-footpeg-mounts-honda
Old Dec 6, 2018 | 03:11 PM
YMRacing's Avatar
They did get back with me, they do make ones that fit the SuperHawk. I ordered a set, received them today, look well made.
Not able to put them on for a few days...My bride of 35 years and I are taking a ride on the City of New Orleans to well...New Orleans to spend a few days to celebrate the occasion. Been the best 5 years of my life...a moment here and there add up you know!
Will report next year!
Thanks everyone for your help!
Old Dec 6, 2018 | 04:08 PM
Those are basically knockoffs of the mfw vario footpegs but presumably made in China and cost less than half the mfw. I've looked at those before and they are a good alternative except how they keep from rotating for adjustment is different than the Varios which use a mating castle nut arrangement between the hinge piece and the arm, where is the knock-offs I believe have a hole and pin arrangement to keep them from rotating which could shear off if not made from decent SS and the aluminum is low grade. The MFW could never shear and made from aircraft grade materials
Old Dec 7, 2018 | 01:25 PM
finepooch's Avatar
I adapted buell drop pegs years ago. I still have not figured out what to do about the height of the rear brake pedal.
Old Dec 10, 2018 | 12:40 PM
How to lower brake pedal
Going from memory back a dozen + years ago, the following steps are in the correct direction
remove cotter pin and lower double but
trim off about 5 mm of threaded rod so rod does not impinge on clevis; no need for double nuts
drill small hole in rod for safety wire rather than use cotter pin and adjust pedal down to taste
I'll check when in my shop and take a picture and post it...
Old Yeller
Apr 7, 2013 07:59 AM
reaper
Oct 19, 2007 05:50 PM
skokievtr
Jul 11, 2007 02:03 PM
FatHawk
Mar 13, 2007 05:42 AM
Blurr
Jul 19, 2006 09:50 PM
