Adjusting Rear Brake Lever
Old Oct 18, 2007 | 06:55 AM
reaper's Avatar
I was wondering if anyone has or if it is possible to change the rear brake lever position. When I apply the rear brake, after applying the front first, I have to raise my foot up a couple of inches to get my foot on the lever.
I would like to lower the lever 1/2-3/4" so that I can slid my foot over versus raising it up to apply the brake.
Any ideas?
Old Oct 18, 2007 | 07:30 AM
redman's Avatar
+1 on THAT Reaper! I've been thinking about the same thing for a while. I have it adjusted all the way lower and it's still way too high.
Old Oct 18, 2007 | 07:34 AM
Randman's Avatar
Moderate-whore
I think there called rearsets....
Old Oct 18, 2007 | 11:10 AM
Well I call them "Realy expensive"... that's what I call them...
Old Oct 18, 2007 | 11:42 AM
killer5280's Avatar
Don't use the rear brake.
Old Oct 18, 2007 | 12:03 PM
Involute's Avatar
Utardian Extraordinaire
Involute is on a distinguished road
I'd have to check to make sure but I'm guessing you can do the same thing I did on my Blackbird (and will do to the SH in time if it's the same)
If you cut off (I used a Dremel) about 1/8" from the BOTTOM of the threaded rod it'll allow you to lower the brake pedal more when adjusting. The limiting factor when stock is the threaded rod makes contact at the bottom when adjusting the pedal down.
ONCE AGAIN............I'M NOT SURE THIS WILL WORK ON THE SUPERHAWK (YET)
Old Oct 18, 2007 | 01:22 PM
It does...
Old Oct 18, 2007 | 06:57 PM
redman's Avatar
cool...thanks
I'll seek and destroy
Old Oct 18, 2007 | 08:11 PM
reaper's Avatar
Yes thanks Involute, something to tinker with tomorrow.
Old Oct 19, 2007 | 01:37 PM
I've done it
Any ideas?
Remove cotter pin, disassemble, remove lock nut, cut off about 5mm (eliminates cotter pin hole), grind smooth for easy threading, slip on flat washer made from 3M grey non-slip peel n' stick tape to top of threads (acts like a crush-type lock washer), reassemble without oem lock nut & thread down all the way, safety wire, and you've dropped pedal 1/2"+ see pic I also pop-riveted a small, thin extension plate under the pedal because my adjustable pegs keeps my boot out farther. Even lowered 1" the peg does not drags at my pace with the rear raised -1/2" with the Penske ride height adjustment.
Old Oct 19, 2007 | 04:19 PM
redman's Avatar
will do skok...thanks
Old Oct 19, 2007 | 05:50 PM
reaper's Avatar
Nice job skokie!
2whltuner
Sep 29, 2016 09:59 AM
superhawkfanboy88
Aug 30, 2012 11:38 PM
Gregw
Sep 28, 2008 06:52 PM
Randman
Oct 16, 2007 02:04 PM
EngineNoO9
Aug 24, 2006 11:45 PM
