Help!! What is this sound??
Old Jan 23, 2006 | 07:43 PM
  #31
gottavtr's Avatar
gottavtr
Re: Help!! What is this sound??
I bet I know what that sound is. It is from a misfire but the sound is all of the transmision parts slapping back and forth. You may hear it in four cylinder bikes as a rattle or just rough running but on a VTR the difference in having every power pulse being sucessful and missing one is so violent that you hear a loud rapp form the transmission. Al of the things that have been mentioned earlier, jetting, cleaning of the slides should be done just to make the bike right and I am sure you will hear a reduction in the sound. Also balance the carbs.
Zach
Old Jan 26, 2006 | 04:16 PM
  #32
BirdofParadise's Avatar
BirdofParadise is an unknown quantity at this point
I had a similar sound, like a ball pean hammer hitting the engine. Noticable about every 10 sec at idle and more freaquent from 2400 to 3000 rpm. I had no reference for the sound since I never heard the bike run before rebuilding it. I used Wileyco CF slipons in place of the smashed off originals. After placing a rag over the exhaust outlets to simulate a more restrictive exhaust the problem cleared up..twas too lean.
A Factory Pro TI jet kit was installed and the noise is gone.
If the noise starts to happen after having run fine and you've made no changes, check the carbs for fuel restriction in the pilot circuit. A plastic like residue can be left behind from fuel and will clog tiny holes and passages.
Aloha
Old Jul 22, 2006 | 11:16 PM
  #33
SillyHawk's Avatar
SillyHawk is an unknown quantity at this point
Well i did get a DYNO jet kit installed a few months ago and it took care of 95% of the "clunking" problem!! i had no idea jetting would make such a difference.
Old Jul 23, 2006 | 01:57 PM
  #34
chico33's Avatar
chico33
I put 48 slow jets, set mixture screws at 1 3/4 out and balanced carbs - no more backfire thru air box and reliable 1050-1100 idle. runs so nice haven,t tried to fine tune mixture.
mattvdsande
Mar 16, 2009 11:12 AM
superbling
May 23, 2008 01:11 AM
svennis
Jul 9, 2007 08:04 AM
HRCVTR1000
Mar 30, 2007 07:38 AM
inderocker
Nov 20, 2006 07:05 PM
