front end swaps???
Old Nov 5, 2006 | 08:56 AM
iscoot's Avatar
iscoot is on a distinguished road
front end swaps???
have a line on a complete late model CBR1000 front end. Is this a good fit?
Is the RC51 a better choice? Is it really worth the trouble?
Feedback welcomed!
Old Nov 5, 2006 | 09:39 AM
superhawk22's Avatar
Do a search, a member on here has a completed cbr1000rr conversion with pictures and instructions. The RC forks are the same length as the SH so that makes things a little easier. As far as if it's worth it that depends on what you use the bike for. If you are just riding around town or just some spirited rides the right fork springs and oil is usually enough. If you do track days or really hard riding then yes it's worth every penny. Not only do you get a stiffer better front end but much improved brakes as well.
Old Nov 5, 2006 | 12:08 PM
Do a search I believe it was Icebud who documented that very swap. Know that it's not a bolt on swap. Well once you swap the races and bearings the front end IS a bolt on swap but I'm doing an RC51 front swap and still want to do things like move the radiators back slightly and still experimenting with bars. Stuff like steering radius and fairing clearance can give you some headaches.
Old Nov 5, 2006 | 11:52 PM
Icebud's thread:
https://www.superhawkforum.com/forum...ead.php?t=2518
Old Nov 7, 2006 | 11:45 AM
bump_evl's Avatar
bump_evl is on a distinguished road
I would do the 1000rr because it has radial mounted calipers. But if you go with the rc 51 you can find a bracket so that you radial mount the brakes.
theosagekid
Dec 30, 2013 09:47 PM
cliby
Apr 26, 2008 05:32 PM
Besucher98
Jun 19, 2007 06:37 PM
Speed_Demon
Jan 21, 2007 09:47 PM
Hawkrider
Aug 3, 2006 11:33 PM
