fork it
Old Aug 23, 2006 | 05:20 PM
plan9's Avatar
plan9 is on a distinguished road
fork it
hey all-
i am a new owner with a low mile 98. i'm a big guy and tip the scales close to 300lbs. my suspension is stock and it's not cutting it. besides losing weight what can i do to my forks to improve the ride? are there simple & inexpensive mods that i can do that will yeild decent results?
i was thinking about progressive springs and a heavier oil.
also, what is the deal with those two screws on the tops of the fork legs that have the "H" and "S" on them?
thanks,
plan9
Old Aug 23, 2006 | 06:50 PM
marmaladedad's Avatar
Hmm?
Get 0.95 or 1.0 kg/mm springs. Don't forget to upgrade your shock spring, too. While the forks and shock are being worked on, it would be a good idea to get them refreshened/upgraded since the bike is older.
The adjusters on top of the forks are to adjust the rebound setting from Hard to Soft. There is no compression adjuster for our bikes. The large nut around the rebound adjuster controls preload.
Old Aug 23, 2006 | 07:39 PM
superbling's Avatar
Yup, get the heaviest rate springs you can find. The rebound adjusters are for the suspension action and shouldn't be "cranked up" just because you're heavy.
See if the owners manual is still under the seat.
Old Aug 23, 2006 | 09:31 PM
I weigh 225 and I have 1.05 kg/mm springs. I would recommend 1.1 or 1.15 if you can get them. You are going to have problems with rebound damping with those stiff springs though, so I recommend a revalve of the forks as well. Thicker oil will help but will then make your compression damping WAY too harsh, as you will already have stiff springs in there.
Old Aug 24, 2006 | 09:51 AM
Chilly996's Avatar
Chilly996 is on a distinguished road
"Super" Moderator? When did that happen. Congrats on the promotion!
Sorry for the jack. Now back to our regularly scheduled thread...
Old Aug 24, 2006 | 03:00 PM
L8RGYZ's Avatar
Plan9? You live in VA?
Old Aug 24, 2006 | 08:17 PM
Yeah, I have "special" abilities. hehe When we fixed the birthdate issue it also allowed custom titles.
inderocker
Jun 7, 2010 12:22 AM
AngryOlaf
May 25, 2010 09:39 AM
HawkRider98
Sep 10, 2008 09:07 AM
