Flush Mount Indicators
First post? Why not introduce yourself? Unless you are a troll?
What recommendation are you looking for? There are a myriad of choices out there, from the cheap (LP Flushies, ~$10) to the expensive (I forget the name, but they are not cheap compared to LP units).
I have Shock Racing LEDs on both my 1000RR and 600RR. I have some LP flushmounts that require slight modification to fit between the front inner and outer fairings on the Superhawk. On the rear I have some expensive Hyperlites that act as turn signals, flashing brake lights, and running lights.
FWIW, you will need to get some special flasher or electronics to slow the flash rate with LED signals. I've had a lot of luck with www.vfxkits.com.
check out these leds i have them on my firestorm 1998 they fit perfectly look and work greathttp://www.1tail.com/sa/cart/detail.asp?pg={91663FBB-3621-4111-8CFB-07FB34D1F978}
the ones for the rc51 are the same part # as the firestorm
450, crf, firestorm, fit, flush, flushmount, front, honda, indecators, indicators, lp, mount, superhawk, vtr
