Dyno result of "Burnie Morgan" airbox mod?
Old Sep 4, 2011 | 06:23 PM
Has anyone done a before and after dyno run to see what the result is of the Burnie Morgan mod (link posted in the KB section - essentially involves removing the air dam in the airbox and cutting back the ridge on the filter)?
Markus?
thanks in advance
Old Sep 4, 2011 | 11:24 PM
Stephan's Avatar
Not on dyno, but before and after there was practically no difference in high revs, and slight improvement in smoothness in low revs. And there was no need to do anything with jetting.
Old Sep 5, 2011 | 05:18 AM
That is pretty well what I had found when I tried it a few years back. However, I have come to realize that the seat-of-the-pants (mine anyhow) is not the most reliable dyno in the world.....
Old Sep 5, 2011 | 06:34 AM
Stephan's Avatar
I agree, it wasn´t exact reply to your question, dyno or AFR measurement tells it better.
Old Sep 5, 2011 | 06:42 AM
I think the only one who may be able to provide an answer is Markus (aka Tweety).... you become well informed on these kinds of things when you have your own dyno (and, of course, an inquisitive mind)
Old Sep 5, 2011 | 07:04 AM
Well, the dyno says it doesn't matter one darned bit in terms of power... It does smooth out the bottom a bit, but i could measure no improvment, and no measurable loss in the top end...
Old Sep 5, 2011 | 07:13 AM
Stephan's Avatar
I have friend with lambda and he can measure AFR (and did some work on my carbs) but to be honest I wouldn´t have do it in this case as I had feeling I rode completely the same bike :-) But there can be diference whether you do it on oem bike (my case before, richer AFR), or properly jetted bike with cans or some other changes.
Anyway This topic is interesting for me as I consider go back to paper filter from BMC, I have some doubts about filtration and low revs could be smoother. Theoretically there can be some loss of peak power and if this mod works, it could offset it, will see :-)
cybercarl
Apr 7, 2013 11:50 AM
GTS
Aug 27, 2012 12:32 PM
FumbleBee
Oct 13, 2010 01:39 PM
mikstr
May 5, 2009 12:01 PM
mikstr
Feb 14, 2007 05:35 PM
