Dyno Jet needle #
Old Aug 13, 2011 | 01:53 PM
!LL Clinton's Avatar
!LL Clinton is on a distinguished road
Dyno Jet needle #
I just put new two bros. cans on the bird with a k&n filter and it def needs to be jetted. Does any one know what number needle to use in the stage 1 dyno kit? I've never done this but I can follow directions like a pro.
Old Aug 13, 2011 | 02:27 PM
aaugsbu's Avatar
aaugsbu is on a distinguished road
I have Devil high mounts on my hawk. When I got into the carbs this winter found out that I had a stage one jet kit installed by previous owner. I got alot of great information from members here on the forum. Many recommend that you not use K&N air filter. Stock seems to be better. I have my needles adjusted to the sixth spot. It is alot better than what it had been before. If you follow instructions well there is a thread on this forum called "carb set up" using stock needles, air filter, main jets and I think a different pilots. I would try this set up before doing stage one jet kit. But, if you need help with stage one I have 180 mains and 45 pilot in the front cyclinder and 185 main and 45 pilot in the rear. I also have the needles shimmed all the way to the sixth spot. Hope this helps.
Old Aug 14, 2011 | 05:28 AM
thanks a million for the advice man! when did you get your exhaust? Didnt devil recently go out of business?
Old Aug 14, 2011 | 06:56 AM
aaugsbu's Avatar
I was lucky and bought the hawk with the Devil's already on. Love the sound.
Philipian Ricer
Jun 24, 2023 04:52 AM
mikstr
May 12, 2018 07:42 AM
autoteach
Mar 15, 2010 01:38 PM
uchi
Oct 22, 2009 06:45 PM
00996rider
Mar 29, 2005 07:40 PM
