Doing coil on cap mod...
Old Jun 28, 2014 | 03:50 AM
  #31
jerryh's Avatar
"Broke the old cap" "wrapped an old bicycle tube around it" "mechanic skills are far better than photographic skills" sjscicluna don't hold your breath on the photos lol!
Old Jun 28, 2014 | 09:38 AM
  #32
Spokes, the rear cylinder runs more rich than the front from the factory. It helps with cooling that cylinder.
Old Jun 28, 2014 | 08:05 PM
  #33
NZSpokes's Avatar
Fair call. But I wasnt keen on using the old caps anyway. I will order some Urethane next week and turn it to the correct size to fit in the hole and fit over the coil. This will resolve the water ingress and wobble.
And it will be red, as it is faster.
Old Jun 28, 2014 | 08:08 PM
  #34
NZSpokes's Avatar
Yes, but the plug was very sooty. I do think this may have more to do with the age of the plug and how eroded it is. I will recheck it when I have turned up the coil retainers and fit them.
Old Jun 29, 2014 | 05:19 AM
  #35
sjscicluna's Avatar
Can u make me a set of retainers
Old Jun 29, 2014 | 07:30 AM
  #36
If you have a look at the head design and how the OEM plugs fit in the hole.. I think you'll see, its not a round rubber retainer that is bets suited for the task. But a retainer that is round at the lower point to seal and steady the cap on plug, oblong rectangular shape at the top to fully seal the spark plug well off from debris and weather.
IOW I don't know how you will "turn" such a cap seal ... on something like a lathe.
Perhaps if you cut it to a rectangular profile, drilled the center and then mounted and turned down the lower section, that might work?
Very interested in what you end up with and you you got it there.
Same for what your process it to machine or turn Urethane
Old Jul 4, 2014 | 07:57 AM
  #37
RoadManiac's Avatar
European Member
i am interested to do this mod as my caps and plugs must be quite old now
only thing
how do you wire it ?
there are 3 wires going to the oem coil and 3 from the new stickcoil offcourse with the white plug on, so i am geussing just cut and solder but wich color go to what ?
also with this you can modify a quickshift from another bike.... must be a standalone unit with only ignition cut off but still quite a easy job...
Old Jul 4, 2014 | 12:36 PM
  #38
NZSpokes's Avatar
My plan is to make a tapered tube to slip over the top. It shouldnt need to rectangular piece if it fits right. Will detail it when I make it.
My partner has just had surgery and is high need at the moment so she take priority. But for the last week its has been very wet here. Everyday to and from work has been heavy rain. Bicycle tubes work as the bike has not missed a beat.
Old Jul 4, 2014 | 12:38 PM
  #39
NZSpokes's Avatar
only thing
Brilliant write up on how to do it. I did it from this.
https://www.superhawkforum.com/forum...cap-mod-23004/
Old Jul 4, 2014 | 04:55 PM
  #40
jerryh's Avatar
Hope you're partner heals up well and steady! Good tip regarding tubes, I get caught in rain quite a bit and will keep that in mind!
Old Jul 4, 2014 | 10:09 PM
  #41
That looks familiar
Glad it helped
Old Jul 4, 2014 | 11:25 PM
  #42
NZSpokes's Avatar
That looks familiar
Glad it helped
Yeah its brilliant Mate. Was very easy to do. Well apart from my lack of soldiering skills.
Old Sep 30, 2014 | 07:54 AM
  #43
twist's Avatar
Originally Posted by VTR1000F
I'm going to do this mod and use all four stick coils for a 4hp gain. Can't believe no one's thought of this before.
just curious, has anyone ever done a duel plug head conversion on the VTR? It's common for older BMW's but is there any benefit for a VTR engine?
Old Sep 30, 2014 | 08:05 AM
  #44
Nice try twist, next you will want to install a second throttle to double HP.
Were those bmws dual overhead cam multivalve motors? (or maybe airheads)
Old Sep 30, 2014 | 10:49 AM
  #45
NZSpokes's Avatar
Where were you planning sticking it?
Old Sep 30, 2014 | 04:46 PM
  #46
twist's Avatar
air heads
Old Sep 30, 2014 | 06:12 PM
  #47
Jack Flash's Avatar
Well take off, eh.
I'm sorry, I have to say something. It's coil on plug, and not cap. COPs for short.
Old Sep 30, 2014 | 06:34 PM
  #48
twist's Avatar
the COPs are always giving me the hairy eyeball.
Maybe adding a throttle to the left side will increase HP?
Old Sep 30, 2014 | 09:39 PM
  #49
98VTRrider's Avatar
That other thread linked is the best collection of info on the subject.
I think reusing the OEM boot is the best way to seal out water/debris
One of my pics in that thread shows the detailed carving I did to get a really good seal on the stick coil. I also used some silicone as shows in Pic #2 of mine
Old Sep 30, 2014 | 10:32 PM
  #50
NZSpokes's Avatar
One on each grip, one for each carb.
Old Oct 1, 2014 | 03:43 AM
  #51
CrankenFine's Avatar
Agree that's the thread & method I'll be using this winter. Someone gave me a pair of coils as payment for a favor.
Old Jun 3, 2015 | 03:34 AM
  #52
NZSpokes's Avatar
Originally Posted by superman22x
You won't get any more power if you don't increase gap with a stronger spark. Coil on reduces the resistance in the line. That's the advantage. V=IR. When your V is 50,000 Volts, your I goes up quite quickly even when you only dropped resistance by 0.01 Ohms. If you are doing the coil on mod, increase plug gap slightly. Maybe 5-10%.
Little update on this. Am now going to open the gap out to 1mm and see what happens.
Old Jun 3, 2015 | 05:43 AM
  #53
Yes, there was someone (I believe it was Tweety on the UK vtr1000.org site. A search will confirm) who dyno'd thier stock coils and then tested the more modern Coil On Plug (COP mod) a.k.a. Stick Coils, back to back to back. There was actually a 2hp difference. Why? I am 99% positive it was because his stock coils were the originals from 1998 with a crap load of miles/use on them.
A lot of people, myself included, do this mod, because thier stock coils are old and instead of buying new stock coils, why not upgrade? Less weight (however little), less parts, less wires. And if you do it right, you buy a set of four coils with harness off eBay, sell the other two coils on here and the mod will be almost free.
Not only that, I'm pretty sure I stated in the very post I made that it was because the stock coils was crap, and I knew it...
smokinjoe73
Oct 13, 2014 03:47 AM
smokinjoe73
Sep 25, 2014 01:42 PM
reaper
Jun 22, 2013 08:53 PM
chemomche
Jan 20, 2013 01:00 AM
chemomche
Apr 21, 2012 06:10 AM
